longer wheel studs with 4th gen rear
Car: 1991 Camaro Z28
Engine: 350ci TPI
Transmission: built 700r4
Axle/Gears: 4th gen rear end
I'm putting weld prostar wheels and I've heard you have to put longer wheel studs. does any one know which ones i need to get? i believe arp brand is the best. anyone have a part number?
Car: 86 iroc, 02 v6 camaro
Engine: 350 HSR, 3800 V6
Transmission: T56, WCT5
Axle/Gears: 9in 4.11 posi, 3.23 LSD
Re: longer wheel studs with 4th gen rear
The stock studs are 2 1/8". The 100-7708s are 2 1/2" and the 100-7713s are 3 1/4", you would need 3 1/4 per ls1 tech...
im pretty sure you are right you have to get a longer stud but i know for a fact you need a Shank style lug nut and washer not the acorn style that most rims use
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
