Wider Iroc Z rims
Car: 1985 iroc z
Engine: 305 HO
Transmission: t-5 5Speed
Axle/Gears: 3.73 rear diff
Wider Iroc Z rims
I have a 85 camaro Iroc z with the l69 motor I am doing some mods and it will have around 300 hp. I already had traction problems to begin and now it will be an even bigger problem. Does anyone sell a wider Iroc z rim by any chance? I actually really do those rims.
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Re: Wider Iroc Z rims
It sounds to me that your traction problems are based around suspension deficiencies - worn bushings, OEM rear control arms and TQ arm, sub-par tires...
Tell us what you have and we will help.
BTW, no one makes a wider IROC wheel - larger in diameter, yes - but bit more than 8.5".
Car: 1985 Camaro IROC-Z
Transmission: GForce T-5
Axle/Gears: 10 bolt 3.73 posi
Weldcraft in Michigan did them for me. Fantastic work. But not cheap, so beware!
Car: 1985 iroc z
Engine: 305 HO
a comp cam xe 262h, hooker shortie headers without the A.I..R system on them, true dual exhaust 2.5 inch pipe, egr delete, smog pump delete and cat delete
Car: 1985 iroc z
Engine: 305 HO
Yes you can widen them for about $400 a pair.
I didn't mention it because there are hardly any 245-50-16 tires left on the market, let alone anything larger (other than a few, select drag tires). So you are really barking up the wrong tree looking at 16" stuff at this point - other than keeping the car somewhat original.
dodgeitclevelan, what tires and size are you running? What about your suspension?
It was about $200 per wheel, plus shipping, which was about $100 per wheel (keep in mind I'm in Canada)
I forgot to mention I widened 17" iroc rims to 17x9.5 so I can run 275/40/17 tires.
Car: 1985 iroc z
Engine: 305 HO
Car: 1985 iroc z
Engine: 305 HO
Car: 1985 iroc z
Engine: 305 HO
This is my weekend project car. I also use it to take my wife to the movies on weekends.
Djmathis123
Sep 29, 2015 01:36 AM
mustangman65_79
Aug 11, 2015 03:17 PM
