I need help with what spacers I need to fit my 4th gen wheels
Old Feb 16, 2015 | 05:03 PM
knuclebone's Avatar
I just purchased a set of ar rebels front-18x8 ,rear-18x10 of ar rebels with 295s on rear I have done research and I have come to the conclusion that I need 2 in spacers all the way around the car. But I have also read that some people have used less than 2in in the rear like 1.75 spacer. Does anyone have a opinion or input to help me out the backspace is 7 1/8 and offset is 41mm. I want a second opinion before ordering all 2in spacers
Old Feb 16, 2015 | 06:59 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: I need help with what spacers I need to fit my 4th gen wheels
Depends on how much hammering you want to do. A 18x10.5 will fit the rear with. 295 using about 6.5 of backspacing and some mild hammering. More spacer will cut down on the hammering but will set the wheel further out and almost outside the wheel well.
On the fron shoot for a final backspace of about 4.5 to fit the 8" wheels
Old Feb 16, 2015 | 07:15 PM
knuclebone's Avatar
Well this wheels are 7 1/8 backspace and a 40 something mm offset. They came off a 02 camaro. I wondering if I need 2in spacers on front and rear or only front and like 1.75in spacer on rear.
Old Feb 16, 2015 | 07:18 PM
knuclebone's Avatar
I have already purchased the wheels 18x8 in front and 18x10 with 7 1/8 bs and 41mm offset is exactly the specs
Frozer!!!
Jan 19, 2024 04:55 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Omega
Oct 1, 2015 02:20 PM
kah992
Aug 19, 2015 02:55 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
