Anybody ever ran a 255/70r15?
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Has anyone ever ran a 255/70r15? Just trying to figure out if they would fit or if they would rub.
Trying to get the most width I can, yet still be within the rules of a 70 or 75 series tire on the stock 15" wheel. Only problem I see is the height, 29" tire.
PS: Yes I realize this is a truck tire size. This is for a dirt track application. Any other tire size recommendations would be appreciated. Has to be 70 or 75 series 15". "No truck, trick, high performance, or directional tires".
Car: 88 IROC
Re: Anybody ever ran a 255/70r15?
Thats what Im thinking. Might rub on the fronts.
Car: 88 IROC
Sounds like I will either have to run a skinny tire or modify the front fenders. Hmmm
I have 275/60r17s on my 88, Id have to go down to a 200/70r15 to get near the same diameter with this rule. Not sure what Im going to have to do.
Anybody good at guessing a tire size by a picture?
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
For the most part, going taller profile makes the tread width narrower - it is just how tires are made to pass durability tests and real world applications.
29" is a really tall tire and would have a lot of sidewall rollover, plus it would drop the effective gear ratio about 12% vs stock 26" tires.
Car: 1991 camaro rs
Engine: 496 big block
Transmission: th400
Axle/Gears: stock rearend. 3.23
I have 295/50 15 on the back. Thats pretty wide. I have 265/50 15 on the front any wider and you have serious rubbing issues when you turn. Hope this helps.it will rub just alittle bit when you go all the way. But i have no rubbing issues in the back.
I know your running a stock car and you have rules on tire size. So cutting the wheel wells is not a pro lem,
Car: 88 IROC
Right now the car has some old 225/70r15s on the front mounted on some 84 z28 wheels. The rear has some old 215/75b15s mounted on some rallys just to move it around.
Going to try and find a 235/70r15 and see how it looks. Would still like to see how close a 255 or 245 would be.
EDIT: Just wanted to add that a 235/70r15 is almost max you can get on the front. Not much room for anything any taller. Atleast Im not going to push it. Going to run the 235/70
RedLeader289
May 28, 2019 01:47 PM
darwinprice
17
Oct 11, 2015 11:51 PM
Linson
Oct 1, 2015 09:50 PM
