tire size
tire size
Hi everyone looking to put a set of 17x8" in the front and 17x9.5" in the rear on my 91 stock suspension looking to get the widest tire i can in the rear without tubing it any suggestions
Car: 1984 z28
Engine: Crate replacement L31R 350
Axle/Gears: 7.625" 28 spline 3.23
Re: tire size
Personally I would run 245/45/17 on the 8's and 275/40/17 on the 9.5's.
A 295 would probably fit the rear just fine with the right offset but needs a wider wheel than 9.5" in my opinion.
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Re: tire size
Skip the 8" on the front and go 9.5" all around with a 275-40-17 tire on all 4 corners.
Car: 1984 z28
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: tire size
The tiny speed penalty of a 275 up front more than offsets the ability of the car to go into a ditch or crash going around a turn. As someone else said, understeer is a concern.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: tire size
If you only want to go straight, why not just use a 15" wheel and a good drag radial? More traction available with a 15
Hotrodboba400
Dec 10, 2019 07:07 PM
TheTraut88
Sep 7, 2015 05:22 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
