wheel questions
Old Mar 23, 2015 | 10:14 PM
turbobuick88's Avatar
Car: 86 Camaro Z28 IROCZ
Engine: 5.0 LB9
Transmission: auto
wheel questions
Newish to Camaros so I need some help with some wheel fitments.
Car:1986 Camaro IROC-Z
I want to do a staggered fitment with a 19" wheel, 9.5" or 10" on the front and 11" wheel in the back. I want the wheels and tires to sit flush with the fenders not tuck, not poke. I was wondering what offsets I would need front and rear to make this happen. Also I would like to check tire sizes too. Front would be a 275/30/19, rear 315/25/19. Any problems running these sizes? any input and pics would help thanks!
Old Mar 24, 2015 | 09:47 AM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Re: wheel questions
19" is an oddball size - tire sidewalls get too small and the selection is not as wide as say 18"or 20" wheels and tires typically. I would push you towards 18" wheels and tires.
In the front, a 9.5" wheel with 5.25" BS will be perfect; a 10" wheel would require 5.75" BS. Both will be flush as you desire. 275-30-19 is the correct size.
In the rear, an 11" wheel would need 6.75" BS to work out flush - others can chime in as there may be some wheel well modifications needed to fit correctly. The 315-25-19 tire would also be correct sizing.
I mentioned 18" in the beginning of my post for a few reasons (hear me out):
1) Tire and wheel availability is better
2) The weight will be significantly less (compared to 19") - better ride and handling
3) Tire sidewall - once you get past 18, the law of diminishing returns kicks in - handling can be compromised as the suspension cannot keep up with the demands of controlling the wheel with the additional spring rate introduced by the much stiffer tire.
Old Mar 31, 2015 | 07:40 AM
Engine: 5.0 LB9
Transmission: auto
Re: wheel questions
Okay thank you! I was planning on getting some Vossen wheels. That's why the 19s because it is the smallest size they offer. I'm also getting coilovers and plan on getting the fenders rolled and removing all of the inner fenderwell plastics.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
