wheel alignment trans am gta
Old Aug 6, 2015 | 02:06 PM
johanlindgren's Avatar
Car: Trans Am GTA 1989
Engine: V8 5,7
Hade rough wear on front tires/inside. so decided to do a wheel alignment. this are the values that were before and after. I hade no trouble where the car pulling to one side or other. but now it pulls to the right, so much that i have to have the steering wheel to the left for it do drive straight. are the values right, or have they messed up the steering wheel alignment some how?
vä= left, hö = right
-00,05 row is separate toe. then camber, then caster
where can i fint the correct values? tried to google it, but no luck.
Old Aug 6, 2015 | 03:07 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: wheel alignment trans am gta
Sounds like they just messed it up a bit. Didn't they test drive it after being done?
Old Aug 6, 2015 | 03:09 PM
Engine: V8 5,7
no they didn't i don't know if they didn't dare do try. i told them to be carful with the car
Old Aug 6, 2015 | 03:25 PM
TTOP350's Avatar
If they didn't test drive it, they don't know its messed up unless you tell them.
Old Aug 6, 2015 | 03:27 PM
Engine: V8 5,7
that i get but what i also was wondering is if the values for the car. camber, caster and toe is correct, since they had trouble finding whats right. if they just whiffed it or if they are correct.
Old Aug 6, 2015 | 03:32 PM
TTOP350's Avatar
I know there are numbers in here someplace.
https://www.thirdgen.org/forums/suspension-chassis/
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
The_Phoenix
Feb 4, 2016 07:10 AM
383backinblack
Aug 15, 2015 06:36 PM
gta power
Aug 13, 2015 06:15 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
