Need Wheel Help
Old Feb 3, 2016 | 10:57 PM
f-bodymikey's Avatar
Car: 84 Z-28
Engine: 355 4 bolt main
Transmission: 700 R4
Axle/Gears: Posi 3.73
Need Wheel Help
Over the weekend I swapped a 97 WS6 rear in to my 84. I used pbr brakes from a 95 Z28 on it. Now to my question what should I do now for rims. My car has 15x7 torq thrust on the back but they stick out in away I don't think looks good now plus I clearancened one of the tires already pulling in to my driveway. Any suggestions are welcomed.
Old Feb 4, 2016 | 06:31 AM
Necron's Avatar
Car: 2002 Camaro SS
Engine: Built LS
Re: Need Wheel Help
If they make the wheel you are using in the 4th gen offset you could buy a pair for the rear but of course you won't be able to rotate.
Another option is to buy a set of wheels that fit the 4th gen and just run wheel adapters in the front. At least you can rotate your tires with this method if you choose a square tire setup.
Old Feb 4, 2016 | 08:16 AM
Car: 84 Z-28
Re: Need Wheel Help
I have read that on here about 4th gen wheels. Do I need a 2 inch spacer to run 16x8 4th gen wheels on the front? Then what tires could I get away with running?
Old Feb 4, 2016 | 11:10 AM
Necron's Avatar
Car: 2002 Camaro SS
Engine: Built LS
Re: Need Wheel Help
Here is the site most people use for info. http://www.skulte.com/adapterfaq.html
If you decide to go that route there are countless threads on that subject you can look at.
70net440
Jan 25, 2016 04:46 AM
Vanilla Ice
Jan 22, 2016 07:11 AM
86iroct5
Jan 20, 2016 09:53 PM
PaulbTTA
Wheels and Tires
Jan 17, 2016 04:36 PM
carattini
Jan 12, 2016 12:51 PM
