18" wheel and tire combo help
Old Jan 20, 2018 | 08:10 AM
Gbear's Avatar
Good morning all, I recently acquired some 18" TT II wheels with 0 offset. Does anyone know if a 245/55 18 tire will fit up front with out rubbing. Have stock suspension and no spacers. I have had one tire shop tell me they will rub on hard turns and another tell me that they will clear??? Thanks
Old Jan 25, 2018 | 07:55 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: 18" wheel and tire combo help
The stock 16" front wheels were zero offset. If you have 8" wide wheels, it should be rather close to stock fit because the tire will be centered in the same lateral location.
Your tires are a little taller than stock. And the width as mounted could be a little different if your wheels are a different width. But you should be in really good shape.
Old Jan 26, 2018 | 03:52 AM
Gbear's Avatar
Thanks for the info. And I think you are on the money. All the tire research I've done looks like the 245/45-18 will be 1" taller overall. 1/2" on either side. Only issue I might have is at full steering lock one way or the other. Thanks again.
p_diddy_to15
Wheels and Tires
Oct 14, 2012 12:59 AM
Confuzed1
Wheels and Tires
26
Sep 23, 2011 12:08 AM
Andy 91GTA
Interior Parts Wanted
Apr 28, 2011 10:38 AM
online170
Jun 2, 2008 05:15 PM
rescuesigns21
May 20, 2007 03:03 PM
