tring to find old wheels
Car: 1986 Sport Coupe
Found wheels, Please remove post
Re: tring to find old wheels
Hit www.car-part.com and do a search. Wouldn't be too surprised if a salvage yard somewhere has had a set sitting in their wheel racks for 30 years. Just checked... 9 pages of results on there.
FWIW Berlinettas all had 14x7 aluminum wheels in gold. S-truck wheels that style were 14x6". Edit - looks like later 2wd S-trucks had a 15x7 steel rally, but they don't interchange with the 86 Sport Coupe 15x7.
Car: 1992 Z28
Engine: 383
Is the back spacing different for the sport coup? They have used all the camaro wheels other then the iroc wheel on the s10 over the years. Even the 91-92 camaro wheel was used on the s10.
I'm not sure why the 2wd truck rallys are different than the Sport Coupe, but if they were the same in the Hollander Interchange guide, the truck wheels would come up in the list on car-part when you search for the Camaro wheels, and vice versa.
At least with the 14" wheels, the 14x7s on my Sport Coupe were much more refined than the 14x6s on my 92 S10. Wouldn't be too surprised if the later S10 15" rallys are similarly cheapened. Could be a really minor difference that keeps them from being a direct interchange.
I know the bezel that snaps in between the spokes is wider on the S10 than on the Camaro and the rim looks the same otherwise but I am not sure if its the same rim or not. If it is, it should have XAZ stamped on it near the valve stem and I can't find a picture of the S10 wheel with enough clarity too see it.
Whoa!!!
Drew,
Thank you for www.car-part.com !!!!! I"m looking at stuff ready to ship I have been looking for 6 months!
THANK YOU!
Drew,
THANK YOU!
I believe the code for the S10 is XAF. Code for the Camaro is XAZ so the black bezel inserts for the Camaro may not fit on the S10 rims and the Bezel for the S10 is a little wider than the Camaro and might look funny, I dunno, still trying to get in touch with some of the dealers with Car-part.com but seems they are slow at answering their E-mail.
Car: `86 SS / `87 SS
I can't speak specifically for the 14" and 15" steelies mentioned, but you may find the Camaro 15" wheels have slightly (0.25") more positive offset than S10 wheels.
madscientist
Nov 29, 2003 12:14 PM
