Formula wheels stuck
Old Feb 17, 2019 | 03:12 PM
Bobby Suth's Avatar
Car: 1990 firebird,1989 Iroc z,1986 fire
Engine: 3.1lt,5.7tpi,3.1mpfi
Transmission: auto,auto
Axle/Gears: 273?277
Sat for 23 year. Wheels are stuck and I don't want to break them and don't want to use heat. I sprayed on blaster and WD 40. No luck
Old Feb 17, 2019 | 03:27 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
Re: Formula wheels stuck
I got them! Pry bar hooked end through a slot and tapped on end of axle lightly with a hammer while keeping pressure on the bar.
Old Feb 17, 2019 | 03:47 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Normally if the car runs you can loosen the nuts a bit and drive on them a bit too if needed..
Old Feb 17, 2019 | 08:56 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
It doesn't run. Not yet anyway. I want to clean the gas tank before I try to start it after sitting for so long. Supposedly he started it every few months up until a year or two ago
Old Feb 17, 2019 | 09:32 PM
1936jdb's Avatar
I used a small bottle jack wedged in from behind to whatever I could find that wouldn't be damaged. Just put a little pressure on it, then tap with a dead blow..
Old Feb 18, 2019 | 12:56 AM
NoEmissions84TA's Avatar
TTOP350 beat me to it. Loosen the lug nuts SLIGHTLY and go for a ride around the block, hitting the brakes and taking quick and hard left and right turns.
Yeah, I read - not running yet.
tpi-hearse
Exterior Parts for Sale
104
Jun 18, 2008 11:39 AM
anesthes
Mar 23, 2004 06:01 AM
dimented24x7
Jun 27, 2002 06:10 PM
TomP
Mar 19, 2002 03:39 PM
Josh91Bird
Oct 16, 2001 06:56 AM
