wheel spacer
Old Oct 21, 2019 | 06:59 PM
merlot's Avatar
wheel spacer
Im looking for new wheel spacers, the ones on the front have a lot of play around the hub bolts, at least 2 mm..couple of questions below.
1. Are spacers safe?
2. How much stud clearance is too much?
3. Who make good spacers?
4. Any help with this would be much apprecated
Cheers Merlot
Old Oct 23, 2019 | 03:09 PM
Zach/90\irocZ's Avatar
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
Re: wheel spacer
post pics and be more specific about play ?
bolted on or not are they hub centric or not
1. spacers with right bolt pattern for wheel and our cars are safe if bolted correctly
2. be more specific with to much clearance ? but no such thing to much
depending on thickness of adapter you may need to trim down due to clearance issue with
wheel hub back especially if wheel doesn't have pocket relief's for weight savings
3. ebay , amazon don't make but sell all adapter I personally run https://www.motorsport-tech.com/
I order custom to where I want my wheels to sit
4. do some research and reading about wheel adapters and terms like lug centric hub centric
learning about tire size backspacing offset as all of it directly affects wheel spacer sizing
Old Oct 24, 2019 | 02:43 AM
merlot's Avatar
Re: wheel spacer
Cheers Zach thank you for the info mate, will follow up on your advice.
Merlot
Old Jul 26, 2020 | 11:28 PM
King E's Avatar
Re: wheel spacer
I have an 84 z28 and bought some American racing wheels to go with my car but the wheels were hitting the wheel wells. Anyone know where I could get some spacers? And what lug pattern or specs they are? Any info helps please and thanks
FAST86IROC
Jan 30, 2006 08:43 AM
