Forgestar fitment question
Old Apr 13, 2020 | 08:10 PM
AWR85Z's Avatar
Hi guys I’m a new member but long time reader. Thanks for the endless amounts of info!
I have a 1985 Z28 and have been doing a ton of research here on wheel/tire fitment.
I am interested in the Forgestar D5 18x10 with a 25 Offset. I would like to run these square with a 275 tire.
After a lot of searching and reading, I believe these will bolt right up with a BBK upgrade and factory 10 bolt.
Does this sound correct?
Thanks for your time!
Old Apr 14, 2020 | 02:32 PM
AWR85Z's Avatar
Re: Forgestar fitment question
No one can confirm that a 18x10 w/ 25et will work front and rear?
Will any spacers be needed to fine tune fitment?
Appreciate any input. Thanks
Tony
Old Aug 25, 2020 | 01:43 PM
89mulletbird's Avatar
Car: 89 GTA
Engine: 6.0L Procharged
Axle/Gears: 4.10
Tony
I'm running 18x10 rear wheels with 20et and it took minor hammering on the inner fender well. I am looking at getting the Forgestars also, would likely need a 1/4" spacer to get the tire stanced properly. On the front it would probably be more like a 1/2" spacer needed.
Old Aug 25, 2020 | 04:47 PM
AWR85Z's Avatar
Thanks for the info. I ended up getting different wheels.
Old Aug 25, 2020 | 04:48 PM
Car: 89 GTA
Axle/Gears: 4.10
What did you go with?
Old Aug 25, 2020 | 04:49 PM
AWR85Z's Avatar
I bought a set of ROH Snypers from a friend.
Vulgar
Mar 4, 2009 10:24 PM
heavy_chevy29
Aug 22, 2005 04:04 AM
CamaroEFI
Jan 6, 2004 01:29 AM
91-Z-Speed
Aftermarket Product Review
Feb 15, 2003 09:47 PM
