Max width tires
Car: 86 z28
Engine: 1970 Chevy 355
Transmission: 700r4 stock
Max width tires
Have an 86 z28 with stock wheels 15x7. Looking around for new tires and wondering what the max width will fit without rubbing? I was looking at cooper cobra 235/60 15’s. The stock tires are 215/65 15’s. I’d like to go a little wider to look better that’s why I’d look at a 60 or 55 series side wall. Overall diameter of the stock is 26”. The 235/60 overall diameter says 26.1”. Just looking to see what others run for a width tire without the rub or mods.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Max width tires
235 is fine and shouldn't rub. You will get various answers on what is too wide and what is not, but that isn't typically until you are considering 295 wide and up.
Car: 86 z28
Re: Max width tires
Thanks for that. I’m trying not to go crazy just nice and little wider to look better.
Car: 1988 Camaro RS
Engine: 383 Stroker
Transmission: TH400 3 Speed Auto
Axle/Gears: 373 Richmond
Re: Max width tires
So, from what I'm reading... if I put a 255/60 r15 on the front of the car it should work just fine?
Car: '90 RS
Engine: 377 LSX
Re: Max width tires
That tire is a bit tall at 27". I cant garantee any rubbing. If you are lowered it could. Might want to step that aspect ratio down a touch to 55 which will bring that height down to just over 26".
Car: 1988 Camaro RS
Engine: 383 Stroker
Re: Max width tires
As far as width is concerned... 255 should work just fine up front without rubbing... correct?
Also, I have no clue what the rim size is on the back (nor does the person I bought it off of) but I knw the tire size is 255-60-r15.... I would imagine that the wheel size is either a 15x7 or 15x8... does that sound about right?
Car: '90 RS
Engine: 377 LSX
Re: Max width tires
If it is the factory RS rim than its a 15x7. A 255 should not rub but its relative to the entire setup. I think you'll be ok.
Re: Max width tires
