YearOne Snowflakes: Direct Replacement
Old Jun 29, 2020 | 03:23 PM
mav75's Avatar
Car: '89 Trans Am
Transmission: 700 R4
OK, so I KNOW that the standard size GTA wheel is 16 x 8 and the YearOne silver snowflake wheels are 17 x 9, but is the bolt pattern different? Could I pull the GTA wheels off and put these straight on the car, or will i have to make any changes (besides new tires)?
https://www.yearone.com/Product/1982...d/sfw179slvv2s
Old Jun 29, 2020 | 04:20 PM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
Re: YearOne Snowflakes: Direct Replacement
Bolt pattern is the same. But you would need to find out the backspacing of the snowflake wheels to see if you will need a spacer to fit correctly in the wheel well without rubbing.
Old Jun 29, 2020 | 05:34 PM
mav75's Avatar
Car: '89 Trans Am
Is anyone running them now? With the front GTA wheels being deeper than the rear, I’d be surprised if spacers up front and/or in back would be needed.
Old Jul 1, 2020 | 08:42 PM
devianb's Avatar
A few members on the board run them. The backspacing is 5.1. Direct bolt on no spacers needed. The hub is larger than stock so you may need a hub ring if there is any vibration. With a 275/40 17 tire the wheel will stick out 1/2" farther than the stock front 16x8, but still be under fender. Close to flush with the fender if you have a LS1 style brakes. The rears should be near flush with the fenders too.
Old Jul 1, 2020 | 10:07 PM
mav75's Avatar
Car: '89 Trans Am
I probably wouldn’t upgrade the brakes, so maybe they wouldn’t stick out that far. I’d just have to figure out what size hub ring I would need. Thanks!
Chuck84TA
Wheels and Tires
Feb 20, 2025 03:47 PM
firechicken76
Wheels and Tires
Mar 16, 2010 03:24 PM
WSX123
Apr 23, 2009 10:08 AM
4playta
Dec 31, 2006 01:14 AM
Ward
Nov 4, 2002 12:21 AM
