Looking into 16 inch wheels from a GTA or GNX
Old Jun 13, 2013 | 08:11 AM
Chuck84TA's Avatar
Car: 1984 Trans Am Recaro Edition
Engine: 355 L98 Vortec 226/234 custom cam
Transmission: TKO-600
Axle/Gears: On borrowed time...
I am looking to upgrade from my stock 15 x 7 wheels to 16inch wheels from a GTA. But looking also at a pair of GNX wheels which are identical minus the hub cap.
Are there other (size) differences between the GTA wheels compared tot he GNX wheels?
Is one more favorable than the other?
Chuck
Old Jun 13, 2013 | 09:15 AM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Re: Looking into 16 inch wheels from a GTA or GNX
Chuck,
Not sure if you know this, but 245-50-16 tires to fit those wheels are becoming scarce at this point - there are only 3 high performance street tires left in that size (down from 10 about 2 years ago).
Anyway, the GTA has specific offset wheels for the front and rear, while the GNX uses the same offset wheels on all 4 corners (TA fronts I believe).
Old Jun 13, 2013 | 11:09 AM
Chuck84TA's Avatar
Thanks Paul-
Yeah, it looks like the 16" is definetly on its way out as far as performance options are concerned. I might have to consider some 17" wheels at some point, however for a stock looking GTA/BMW look they are priced rather stratospherically.
Chuck
Old Jun 13, 2013 | 12:38 PM
paul_huryk's Avatar
Originally Posted by Chuck84TA
Thanks Paul-
Chuck
If the price of GTA look alikes is too high, why don't you look into some other wheel designs? Keep in mind that that type of mesh style wheel really limits what brake systems you can run. May not be an issue right now, but if you want to upgrade, some wheels will be useless.
Old Jun 13, 2013 | 01:30 PM
Chuck84TA's Avatar
Good point on the brakes. Having just replaced my stock brakes for a marginal increase in performance with Stillen rotors and pads, I have little appetite right now to spend serious bank on some brakes worthy of 17" wheels.
I imagine that my stock delco/moraine 10.5 discs is a little insufficient for some 17"+ wheel/tire combo... let alone the ol' 16" original GTA wheels/tires should already give my stock brakes a run for the money.
I think I'll go with the 16" GTA's and work with BFG Sport Com 2's until I re-do my brakes.
Old Jun 13, 2013 | 01:35 PM
Chuck84TA's Avatar
Looking into these.. seem to have some good reviews on Tire Rack's site
http://www.tirerack.com/tires/tires....A&autoModClar=
Old Jun 13, 2013 | 01:52 PM
IMissMy86TA's Avatar
Car: 1991 Trans Am Vert
Engine: 5.0 TPI
Transmission: T-5 baby
these are mine.. like them a lot..and not expensive
http://www.tirerack.com/tires/tires....AXHP&tab=Sizes
Old Feb 20, 2025 | 03:00 PM
thelegend0210's Avatar
Car: 1991 Pontiac Firebird Trans Am GTA
Engine: 5.7 350
Edit: sorry posted in the wrong thread.
Old Feb 20, 2025 | 03:47 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Originally Posted by thelegend0210
Sorry for bringing this thread back to life, but new member here and new owner as I just bought a 91 GTA. When it comes to these wheels, what size tire are you guys running on them? 245/45?
tire options have dwindled for 16s. 17s were hot in the early 90s. Go for 18s from gbodyparts
Iroc-Z28Man
Wheels and Tires
Apr 27, 2012 12:06 PM
slowfast
Group Purchases
Aug 5, 2006 09:02 PM
Ward
Nov 4, 2002 12:21 AM
442guy
May 24, 2001 03:08 AM
