Need Help 15x7 Pro Star Wheels
Old Jun 15, 2021 | 10:52 AM
SMKN327's Avatar
Car: 87 Camaro Z/28
Engine: 327 SBC, 495/481 lift, Dem 625cfm
Transmission: B&M TH350 Stage 2
Axle/Gears: 3.90
I have an 87 Camaro Z/28, Stock rear end and just bought some Weld pro star clones made by vision. They're 15x7, 4" BS/0mm offset. I need to know if I can put 245 60r15's on the rear with out rubbing. I'm trying to get the rear tires out just under the fender flare. Any help would be appreciated. I found a great deal locally on some Milestar Streetsteels, but the deal ends soon and wanna know if i can tuck these bad boys underneath. Thanks!
Old Jun 15, 2021 | 04:14 PM
SMKN327's Avatar
Car: 87 Camaro Z/28
Axle/Gears: 3.90
Re: Need Help 15x7 Pro Star Wheels
Don't everybody answer all at once...Look I'm lost here. Stock rim was 15x7 4.25" Backspace +19mm offset. Bottom line new wheels 15x7, 4" backspace with 0mm offset. Just wanna know if a 245 60r15 will fit our cars on the rear with that wheel. Can anyone help me please?
Old Jun 15, 2021 | 09:47 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
Should easily fit. Could most likely go with a bigger and wider tire then a lil 245
Old Jun 16, 2021 | 04:03 PM
SMKN327's Avatar
Car: 87 Camaro Z/28
Axle/Gears: 3.90
Thanks so much! I’m excited! Just ordered them today!
Xephy
Wheels and Tires
17
Jan 16, 2014 02:02 AM
robg91z
Wheels and Tires
May 13, 2012 01:07 PM
89'CamaroRS
Jan 29, 2009 07:31 PM
FireRed91Z28
Feb 12, 2004 05:36 PM
