Tire rubbing frame
Tire rubbing frame
Stock size tires are rubbing the frame in tight turns even when going slow. The rear rims are in the rear and the fronts are in the front. Only happens on the front side. Everything is stock size so i really have no clue what it is.
Engine: 4++,350 & 305 CIs
Re: Tire rubbing frame
Pretty normal.
Don't hold the steering on the stops, no need to go that far.
Car: 1984 Z28 stock
Axle/Gears: Stock
Yup, its normal. Have the same tires on my 89 formula 350.
