91 Formula Wheels
Old Feb 26, 2025 | 01:00 PM
Scotty54's Avatar
Car: 91 Formula
Engine: 2005 LS2
Transmission: 2002 T-56 6-speed
Axle/Gears: 4.11
91 Formula Wheels
My 91 Formula came with an extra pair of wheels - the PO said they are the original rear wheels and he replaced them with front wheels. Can someone explain this? The extra wheels are 16 x 8. Not sure of the width of the wheels installed but they appear to be wider.
Old Feb 26, 2025 | 01:24 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Re: 91 Formula Wheels
I'm not sure which wheel you have, but I know the PW7 wheels (see photo) have different offsets front and rear. The fronts have a deeper dish to them, and a lot of folks prefer that look at all 4 corners. So they will get an extra pair of front wheels and run them on the rear.
Here's a car with the PW7 wheel.
Your car may have this style of wheel....I'm not sure if the offset is different front-to-rear on this style of wheel or not.
Old Feb 26, 2025 | 01:36 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
All 3rdgen 16x8 factory wheels have a front and rear offset.
Use of 4 front wheels makes tire rotation much easier.
No one knows why gm did the wheels like that. Goofy
Old Feb 26, 2025 | 07:47 PM
Scotty54's Avatar
Car: 91 Formula
Engine: 2005 LS2
Axle/Gears: 4.11
DynoDave - my wheels are the same as in your second photo. Despite the different offset were all four still 8 inches in width? Are these wheels referred to as the WS6 wheels?
Old Feb 26, 2025 | 08:19 PM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
Yes. 16x8 front wheels have 0 offset. 16x8 rear wheels have 16mm offset. And yes, they're WS6 wheels.
Front wheels on the rear fit about 5/8" farther outward on each side than rear wheels do, giving the car a slightly but noticeably wider stance. No wheel well clearance issues and no suspension issues. I ran four front wheels before I went to 18" wheels and bigger brakes. I wouldn't say it had any effect on handling, + or -, but the appearance was noticeably more aggressive.
And if you drive the car a lot, then rotating the wheels/tires will be a simple task, as already stated, if you feel rotating tires matters, which I don't, unless there are signs of unusual tire wear.
Old Feb 27, 2025 | 06:55 PM
Scotty54's Avatar
Car: 91 Formula
Engine: 2005 LS2
Axle/Gears: 4.11
Thanks for the replies!
punzak9
Wheels and Tires
Jul 15, 2019 07:34 PM
F-Body Int
Exterior Parts for Sale
Aug 16, 2018 10:24 PM
primaryfitness
Wheels and Tires
Jul 25, 2011 05:45 PM
Randy Nerenberg
Dec 26, 2005 06:54 PM
Red WS6 Ram Air
Feb 16, 2004 08:09 PM
