Torq Thrust II backspacing
Old Mar 11, 2002 | 07:17 PM
bluez350's Avatar
Car: 1991 Camaro Z28
Transmission: 700 R4
I just bought a set of torq thrust II's, i wasn't sure what the backspacing was. The wheels are 17x8's. I ended up getting 4.75 backspacing b/c they don' offer them in 4.5. So are these going to work on my car which is a 91 Z28. And tire size....i was figuring 245x45 b/c 275x40's will not fit on a 8 inch rim. So any help anyone can give will be much appreciated.
Old Mar 12, 2002 | 07:58 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
Re: Torq Thrust II backspacing
yes they will fit as far as not hitting the struts. car craft used a 17x9.5 with 5.5" backspacing. the only thing they had to do was grind a little off the tie rods to clear the rims. the only problem i forsee would be them hitting the caliper at the mounting flange. may need to grind some off there.
Old Mar 14, 2002 | 01:07 PM
SLP-GTA's Avatar
Car: 1991 Formula (sold)
Hmmmmmmm
I thought CC used Edelbrocks 409
Old Mar 14, 2002 | 07:47 PM
mrr23's Avatar
Engine: 360 HSR
Re: Hmmmmmmm
not sure what wheel they used. i just remember the size and backspacing. just found the article. they used centerline aztec wheels. and this was chevy hi performance june 2000. now the january 2001 issue shows a camaro with the torque thrust wheels.
Old Mar 23, 2002 | 12:16 PM
82firebird's Avatar
Car: 1982 Firebird
Engine: sbc 307
Transmission: 200
Car Craft used the Edelbrock 409's when they did the Formula, turned out pretty nice too..
Old May 8, 2012 | 10:17 PM
CRAZYCHUCK13's Avatar
Car: 91 Z28
Engine: 383-Carb
Transmission: TH400/3500 Stall
What Is The Back Spacing For A TT11 W/17x9.5x5.5(b/s) On The Front Of A 91 z27?iI wanna use 17x9.5x5.5(b/s)w/275/40z/17'sI Know Ima Need To Message A Lil!!But Need The b/s For The Front W/That Wheel Size!Can Anyone Help?
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
brockerboy
Wheels and Tires
Sep 17, 2015 03:59 PM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
Brian Anderson
Wheels and Tires
Sep 12, 2015 06:12 PM
