4th Gen Aluminum Driveshaft
Car: 98 Camaro/85 Camaro
Engine: 3.8L/ 355 CI
Transmission: Auto/ TH350
Axle/Gears: 3.23 Posi
Ok ive seen a few aluminum driveshafts for some 4th Gen Camaros and firebirds on Ebay lately so i was wondering if they would be compatible with my 85-Z... cuz if it is then im gonna be gettin one :rockon:
Car: 82 Firebird SE
Engine: 350 CCC 4bbl
Axle/Gears: 10 Bolt, 3.23
As long as it is coming from a LT1 or LS1 f-body, you can use it if you have a 5 speed or 700r4 trans. The TSB on the 4th gens used a 3rd gen 1LE driveshaft. Any one else, am I correct? Good luck.
Engine: LO3;383tpi
I just bought one...
I just bout one out of a 2000 TA, and posted the same topic about 4 or 5 days ago. They said it would work....I believe they're correct. Look in The Summit Magazine and you will see an aluminum driveshaft that fits '82-up V8 camaros. So I'm keeping my fingers crossed and hope that da#$ vibration stops once it's installed....
1992rs/ss
Jan 31, 2025 05:10 PM
ambainb
Apr 25, 2016 09:21 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
