AWD camaro?
Old Oct 15, 2003 | 06:48 PM
nicamarvin's Avatar
AWD camaro?
I was reading about the GMC typhon I that truck was really mean and fast, I was wandering I is posible to put the alltime 4wd sistem in a camaro, well the car is lither than that truck, and a v-8 would make more pawer..
thanks
Old Oct 15, 2003 | 06:50 PM
conlinj's Avatar
I don't think you could fit the transfer case nor the axle in the front without lifting the motor up 6+ inches
Old Oct 15, 2003 | 06:52 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
You could fit the AWD setup in the front of the car but the way everything lines up you'd have to eliminate the engine to do it. The truck sits a lot higher and has room under the engine to work with....you only have about 8" between your oilpan and the road.
edit: You beat me to it.
Old Oct 15, 2003 | 08:21 PM
RJR99SS's Avatar
there was a topic about 4x4 camaros, and some people have actually built them. Of course they had to lift the body.
But there's basically no way to make an awd camaro without significantly raising the body, which kind of defeats the purpose of awd.
Old Oct 23, 2003 | 10:46 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
I think all the 4wd Camaros were bodies on truck frames... but that's just my guess.
Old Oct 23, 2003 | 12:55 PM
drop-top IROC's Avatar
Engine: 305 TPI (LB9)
Transmission: WC T-5
Old Oct 23, 2003 | 01:00 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
That's a little more tasteful than most I've seen lol
Old Oct 23, 2003 | 01:13 PM
4x4 Camaro
my favorite... ( I messed up the previous post)
Old Oct 23, 2003 | 10:08 PM
Tom84L69's Avatar
Car: 84 Z28
Engine: L69: cam and porting
Transmission: T5, 3.73 rear
Bet she handles nice....is that a 1LE car?
Old Oct 25, 2003 | 06:18 PM
88 350 tpi formula's Avatar
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
I like how well they did it! you can't even tell its not stock
Old Oct 25, 2003 | 06:56 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
well.... you could always cut the entire back half of the floorpan out, mount the engine backwards in the rear of the car, have a transfer case send half the power to the rear and half to the front... then you just fab up a custom K member that will let the front axles pass thru................
hehe, anybody got a welder, money, and a lot of free time?
Old Oct 26, 2003 | 05:02 AM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
that's actually not a bad idea, travis.... especially if the car is being used exclusively as a two seater.
Old Oct 26, 2003 | 08:47 AM
Jokerman's Avatar
Engine: slowtacular L03 305
Transmission: slushem 700r4
You know, what about fabbing up an awd system useing some subaru parts? Or audi? I know there would be alot of cutting and such, but it might be possible there. Or if you want to spend alot of money find a junked skyling (r33 or 34) and use that system (much better than full time all wheel drive).
Old Oct 26, 2003 | 10:19 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
if you're willing to heavily mod the front end, you could always put any east-west engine in there, and use its transfer case... then the rear wheel power can go back thru the trans tunnel to the rear.....
but i dont like most of thoes systems.. they're bias to teh front.. i like it set to more of the rear........ some of the newer ones are totally computer controlled, so that might not be a issue...
Old Oct 26, 2003 | 10:21 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
btw, yes at that point you dont have a V8.....
but if you got a decient V6 doing that and put a turbo on it, noone would notice....
and id like to see someone call **** on a turbo V6......... dont forget there was a TTA....
Old Oct 26, 2003 | 02:08 PM
Jokerman's Avatar
Ok so a subies won't work (longitudinally mounted engine, but a flat four is half the length of a v8 so space is an issue) but the skylines should seeing as it is rear wheel drive until the rear brakes traction and then starts sending to the front. Also an inline turbo 6 has a pretty decent length to it so it should work. Just to give you an idea here is a pic of one. Some fire wall work and trans tunnel work should allow for it to all fit and the skylines have been put to some serious power so you shouldn't have too hard a time keeping it all together with a high hp high torque V8.
By the way subies are biased towards the rear as is mitsubishi and most of the audis (although i am 100% sure). In fact i believe that volvo is one of the few that has a bias towards the front in their awd system.
Old Oct 27, 2003 | 09:17 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
I downloaded a video of a Skyline with plenty of mods getting raped by a 4th gen, LT1 with just bolt ons. So, I'd stray from that motor lol
Plus, if you are turning 4 wheels, in a heavier car than you got the engine out of, torque must be an issue. How can a 4cyl cut it?
Old Oct 28, 2003 | 06:37 PM
Verviticas's Avatar
Engine: L98 5.7
Ive seen a dyno video of a skyline with 1233hp and weight of 1500lbs, NO camaro will ever beat that. That car literally accelerates as fast as any crotch rocket, and its for sale! only 730K!
Old Oct 29, 2003 | 01:33 AM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
Couldn't you somhow get a camaro body on the blazer frame and go from there? I thought I heard someone say they put a camaro body on an S10 blazer.
Old Oct 29, 2003 | 06:43 AM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
What about an AWD system from something more similar to a domestic car... say an astro van? anyone have any opinions?
Old Oct 29, 2003 | 07:48 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
sure... and it would look exactly like the pic above.
you have to jack it up in the air for that to work. the parts dont fit IN the car.. so they have to go under it.
Old Oct 31, 2003 | 09:37 AM
matt shutt's Avatar
Car: 84 T/A
Transmission: t5
awd not 4x4 camaro
hey nicamarvin i know what your talking about you want a stock height awd camaro not a camaro on a fullsize blazer frame i from decatur IN home of LINGENFELTER PERFOMANCE father of the worlds fastest street driven corvettes (225 mph) i go over there alot they built the QUADRADUECE and QUADRADUECE 2 for summit using the typhoon drivetrain i know what everyone else is saying about clearance problems under the engine but lingenfelter has built an ALL WHEEL DRIVE CAMARO before it was a 4th gen though i dont know how they did it no one would tell me but belivle me i saw it smoke all four tires no proble try LPE.com i cant remember the phone # and im in kuwait so i cant get it for you good luck!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
BADNBLK
Nov 16, 2016 09:12 AM
porkenstein
Convertibles
Aug 31, 2015 12:54 PM
