knock sensor correct static resistance
Old Jun 11, 2005 | 04:17 PM
hunterdaj's Avatar
I have 2 knock sensors, one from a '91, and one from an '88. Both TPI. The '91 gives a static 3.8k ohm res. The '88 gives a 101k ohm res.
Which one is good/bad?
Both do climb in resistance when struck.
Any info appreciated
Old Jun 11, 2005 | 04:40 PM
3.8TransAM's Avatar
Engine: all 225+ RWHP
Transmission: all OD
Do a search on knock sensors.
The 90-92 305 and 350 sensors are different numbers
The 85-89 305 and 350 sensors are different numbers.
I believe the values u stated are pretty correct, but u need to have the correct one for the application.
later
Jeremy
Old Jun 11, 2005 | 05:11 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Yep, both sensors are good. The 3.9K is for a Speed Density system computer and the 100K is for the MAF System computer.
Old Jun 12, 2005 | 12:01 AM
hunterdaj's Avatar
Appreciate the info. I did do a search, though there is a lot of posts to sift through. Is there an FAQ on sensors and all their values etc.? If not it migh be a good asset for quick reference.
Thanks again...
Chuck84TA
Jul 15, 2016 09:05 PM
Andrew6.688
Dec 13, 2015 10:59 AM
bryanwood74
Sep 24, 2015 09:50 PM
db057
Sep 4, 2015 07:57 AM
bamaboy0323
Sep 3, 2015 06:07 AM
