What is everybody running for brake upgrades?
Old Sep 12, 2002 | 07:57 PM
87transam5.7tpi's Avatar
I'm getting ready to upgrade my brakes just wonderin what everybody is running. I did a search for this and didn't find much and plus I thought it would be fun to see what everybody's using.
Old Sep 12, 2002 | 08:03 PM
onebad82z's Avatar
Car: 1982 Z28
Axle/Gears: 12 Bolt
Converted to 1LE set up all around from factory J65 setup..for the money it is by far the best safety mod I have done to my car to date.
Old Sep 13, 2002 | 07:13 AM
ebmiller88's Avatar
Just did the 1LE swap on my J65 '88 Iroc. Like onebad said, the best thing I've done yet. You could always go with Baer, but that's a lot more cash. I also rebuilt my suspension at the same time and the overall difference is amazing.
Check out my rebuild page for pics and hints of the install. Click on the first 2 links:
http://photos.yahoo.com/taramiller72
Good luck!
Ed
Old Sep 13, 2002 | 08:16 AM
so did both of you use the spohn kit? and was modifing the spindles hard? thanks
Old Sep 13, 2002 | 10:11 AM
ebmiller88's Avatar
No and no. I was one of the last guys that I know of to get the caliper brackets and hardware from GM at GMpartsdirect.com. Then I just pieced together the rest of the parts: calipers from autozone, earl's braided lines, new prop valve and used M/C from a board member. It was very easy. I would however recommend doing the Spohn kit. He gives you everything you need in one complete package for a reasonable price, adn you won't have to go out and find things therefore wasting time. I'd also buy AndyZ28's 1LE Plus CD. It will show you exactly how to do the whole upgrade.
I modified my own spindles from a wrecked '91 RS with a milwaukee bandsaw. It's not hard at all really. If you have to drive your car, I'd get some used spindles and get the kit so you won't be without wheels.
Ed
Old Sep 13, 2002 | 10:30 AM
onebad82z's Avatar
Car: 1982 Z28
Axle/Gears: 12 Bolt
Same as Ebmiller88 here..did it myself with all the pieces.Go with the Spohn kit..it will make life easier.
Old Sep 13, 2002 | 06:58 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Me too, did the same as Ebmiller88. Bought from GMpartsdirect 2 years ago. The only way to get all the parts is thru Spohn now.
Old Sep 13, 2002 | 08:32 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Baer Track with drilled rotors (13" rotors) - about $1100 complete. Only fits under 91-92 Z wheels, otherwise must go to 17" wheels.
Old Sep 14, 2002 | 09:32 AM
PF Flyer's Avatar
Car: 87 T/A
Engine: TPI 350 ci
Transmission: 5 speed
I converted to the 1LE package up front. The kit is from SSBS. I couldn't wait for Steves kit to formulate, (sorry Steve) as I was re-doing my front suspension at the time and it was necessary to complete then.
The rear is a 9bolt with the 12" rotors already.
Attached Thumbnails What is everybody running for brake upgrades?-summit-ta-3.jpg
Old Sep 14, 2002 | 09:51 AM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
13 inch Baer Brakes.
Attached Thumbnails What is everybody running for brake upgrades?-brakes.jpg
Old Sep 14, 2002 | 10:19 AM
iroc2nv's Avatar
Car: 1987 iroc-z custom
Engine: 355 tuned port
Transmission: 5spd baby, only way to go
Axle/Gears: 3.45
i have been doing alot of research on braking for our cars and the thing that i have found is that baer is the best bang for you buck...yes you will pay alot more but they are better!! im getting 16inchers when i get my new rims...
iroc2nv
Old Sep 14, 2002 | 08:51 PM
bigbrianiroc-z's Avatar
ebmiller88 how much did u spend on the total upgrade on your suspesion and what all did u put on. im lookin to do some suspension mods and i dont really know were to start. thanx for any advice.
Old Sep 14, 2002 | 09:52 PM
FIRECHICKEN's Avatar
Car: '89 Formula 350
Engine: 5.7L L98 TPI
Transmission: 700-R4 Automatic
Axle/Gears: 7.5 disc posi 3.23
HeySuperman, if I go crazy can I still call you superman?
It looks like those Baer brakes don't clamp onto the entire rotor?? Also what wheels are those and where did you get them?
Old Sep 14, 2002 | 11:46 PM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
The wheels are ROH Snypers. I got them from www.jdwheels.com , they are great people to deal with and have some damn fast shipping. Only took three days for my wheels to get to me when I ordered them.
Old Sep 15, 2002 | 12:11 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Axle/Gears: 3.23 Dana 44
iroc2nv
Only the high end Baer kits are better then 1LE brakes. Like Baer’s 13 inch brake kit. PBR makes Baer stuff. PBR also makes the 1LE calipers. The low end Baer kits are pretty much the exact same thing as the 1LE brakes just cost more and have Baer written on the caliper.
Old Sep 15, 2002 | 12:20 AM
SSupaNatural's Avatar
Car: 1992 Z28
Engine: fivepointsevenleeters
Transmission: nothing right now
you serious? the track kit clears the rims?! are there any modifications at all? cause I wanted to use 17x9 SSrims/adapters for daily driving and still use my stock 16x8's for the track. Can you post a pic or can anyone confirm this? That would be SO COOL if it was true.
Old Sep 15, 2002 | 08:47 AM
paul_huryk's Avatar
Here you go...
Attached Thumbnails What is everybody running for brake upgrades?-frwheel.jpg
Old Sep 15, 2002 | 10:06 PM
PF Flyer's Avatar
Car: 87 T/A
Engine: TPI 350 ci
The Baer kit requires a core charge for spindles, the SSBS does not. The calipers are all made by PBR.
13" aren't necessary as the pad/caliper doesn't provide that much clamping or 'swept' surface. Notice the picture in Superman's post. All of the rotor is not being used.
Basic 1LE brakes work, no matter where you get them and how much you pay. I just prefer to pay only for what I have to.
Attached Thumbnails What is everybody running for brake upgrades?-1le-wheel.jpg
Old Sep 16, 2002 | 10:30 AM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
I run the BAER Track system up front and the 91-92 rear disc setup.
I will never own another thirdgen without these brakes on it.
Old Sep 16, 2002 | 12:59 PM
james_85Z28's Avatar
Car: 2003 Porsche C4S
Engine: 3.6L
Transmission: 6-speed Manual
the 13" kits and the 12" kits use the same pads. Basically the larger rotors act like a larger heat sink to dissapate the heat. That is why they are effective.
Old Sep 16, 2002 | 07:40 PM
pianiy's Avatar
Neither does the 1LE setup.
Old Sep 16, 2002 | 09:25 PM
So after all the arguments who has the best but still afordable brake systems?? 1LE Baer Willwood Alcon SSBS
Well!!!!
Hey how bout some prices you guys paid while your at it!
Old Sep 17, 2002 | 09:20 PM
redlineform's Avatar
The 13" brakes do act as a larger heatsink, but their real advantage is that the calipers are clamping further from the center of the spindle-----superior leverage
Old Sep 17, 2002 | 09:23 PM
superior leverage--- try using your 10" ratchet to remove a lug nut, then try a 16" breaker bar.
Old Sep 21, 2002 | 07:31 AM
ebmiller88's Avatar
Let me give you a quick rundown of what I did:
Brakes:
GM 1 LE brake brackets/hardware: $330 shipped
EBC brake pads: $150 (Tirerack)
Reman front calipers: $55, (Autozone)
Lines: $85 (Earl's)
Prop valve: $55, (Dal at VanDevere Olds)
Master cyl: $20, used
'89 9 bolt rearend W/PBR brakes, complete: $200
New GM e-brake cables: $50 (Liberty Pontiac/GMC, Charlotte, NC)
Rear caliper rebuild kits/seals: $30
Front susp:
ES bushings: @ $200 - A-arm, sway bar/end links, engine mounts, dust boots, etc. (Summit)
Moog suspension parts: @ $300 - Ball joints, center link, all tie rods
Hotchkis tie rod adjusting sleeves: $50 (Jeg's)
Bearings, seals, misc parts: $50
KYB GR-2 struts, (2): $43 ea, (Tirerack)
New GM coil spring isolators: $20
Rear susp:
BMR LCAs and adj. panhard: $170 shipped, group purchase
ES bushings: @ $60-- tranny mount, torque arm, swaybar, end links, etc. (Summit)
KYB Gas-A-Just shocks, (2) : $29 ea, (Tirerack)
New GM coil spring isolators: $25
POR-15 paint for all suspension parts: $30 (PRO-15.com)
Eibach Pro-Kit springs: $210 shipped
That's a rough guess, but it's right at $2000, give or take a few bucks. I did it all at once so if you have more time you can budget a little better. But I think I did pretty good and I love the results. The car is really fun to drive now.
To think all this started when I couldn't get it aligned!!
Ed
Old Sep 22, 2002 | 10:37 AM
Which KYBs are the ones to avoid?? The gas adjusts or the GR2s. I heard one is way better than the other. Any idea???
Old Sep 22, 2002 | 01:17 PM
ebmiller88's Avatar
Get the GR-2 front struts and the Gas-A-Just rears. Don't get the GR-2 rears.
Ed
Old Sep 22, 2002 | 02:20 PM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Don't you have to get rid of your AC to do the 1LE conversion?
Old Sep 22, 2002 | 02:53 PM
ebmiller88's Avatar
87WS6, oh no, no.
The brake system has nothing to do with the A/C. 1LE car just didn't have the A/C drom the factory, that's all.
The 1LE brakes are all that and a box of cookies.
Ed
Old Sep 22, 2002 | 04:11 PM
Ok, So if I have the PBRs already installed on my 89 does that mean I still have to change prop valve and master cylinder to go to 1LE set up?
Are the auto zone caliper remans any good?
Old Sep 23, 2002 | 07:19 AM
ebmiller88's Avatar
There's 2 threads on this very topic just a bit below this one.
Read those for the info, but you may have to change the prop valve. The M/C you already have is the right one.
Ed
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
sailtexas186548
Jan 19, 2016 12:21 PM
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
