1LE bracket to spindle bolts
Old Apr 28, 2002 | 05:33 PM
Eightyninef's Avatar
part # 11508133 is a bolt that goes from the 1LE front brake bracket to the 1LE spindle. Is there a GM washer that goes under that bolt ?? Or does it even need a washer? part # anybody ???
also, I have the GM bango bolts, and the GM 1LE brake hoses. I have these steel washers for the bango bolts. All other brake hoses I have seen were copper washers for the brake hose. does anybody have a GM part #, or is the steel washers OK. They are in a GM bag of 10 and say off-road use only. IS there copper available from GM?
thx
Larry
Old Apr 29, 2002 | 05:15 AM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
The bolts do not use washers. Go to my website www.3rdgensolutions.com I have "installed" pictures of all the 1LE front brake components.
Use copper!
Old Apr 29, 2002 | 07:08 AM
I have gotten conflicting information on using copper or steel bango bolt washers. copper may react with the aluminim. The steel washers are directly from GM, and are thicker than copper.
I have to look at my friends TTA. that'll be the final answer
Old Apr 30, 2002 | 10:18 AM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
The rear PBR brakes I just disassembled off an 89 Formula had copper washers on them (judging by the brake dust build up, those were the original washers). I'd be hesitant to use steel washers, for fear that I'd strip the threads in the caliper before getting them to compress enough to seal. I used copper on mine.
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
billybob6110
Sep 23, 2015 01:30 PM
TheTraut88
Sep 11, 2015 05:16 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
