Will a 255/50/ZR16 fit all around?
Car: 89 IROCZ28
Engine: 350TPI
Axle/Gears: 2.77 Gears
This is on an 89 IROCZ with the stock 16x8 IROC wheels all around. Thanks for the info in advance.
1989 IROCZ28, 5.7 liter TPI, 700R-4, 2.77 Rear, Gutted Air Boxes, Flowmaster 80 series muffler with dual 3 1/2" tips, Clarion 8575 Head, Infintiy Kappa 4x6 plates, Stock 6x9's, Alumapro 10" Aluminum Sub in sealed box, Orion 400 watt amp
Car: 1986 Iroc Camaro
Transmission: Th700R4 Jr. Raptor
I also would like to know what the widest tires you can fit on a 16X8 IROC rim are too.
Can we fit somethign cool like 255/45/r16's or anything?
The 255's will definately go on the back there is no problem. You could possibly go 265 on 16's. But the front is a different story. I have 235's on the front and they are rubbing on my sway bar when ever I make tight turns. The sway bar is a suspension tecniques sway bar and is condierably bigger but even with a stock one I don't think that you could get 255's on without some modification down there.
Cristos,
Hey I saw you're from aliso, you should email me some time. I've been trying to find other people around here with thirdgen's.
Late,
Jim
Cristos,
Late,
Jim
Car: 1991 Camaro Z28
I have 255/50/ZR16 all the way around on my stock '91 wheels which are the same size as the IROC's. The rear has no problems but the front will occasionally rub on the inner fender well during high speed turns. Nothing extreme though.
1991 Z28 - 350 TPI, T56, McLeod street clutch, ported plenum & runners, AFPR, Holley Annihilator ignition box and wires, Hooker shorty headers w/o AIR, Flowmaster muffler, homeade ram-air, SSM subframe connectors, Kenny Brown STB, Global West steering box brace, Steve Spohn adjustable torque arm and T56 crossmember
Car: 1989 Firebird Formula
I have 245/50/16 on the front and 255/50/16 on the rear. You could put a 265 on the rear, but you wouldn't get the full amount of traction out of the tire until you get a different rim size like a 17x9.
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
i was talking to a guy at a local tire place yesterday,a nd he said he had 255s at all 4 corners on his 86 IROC with no problems at all. i guess they fit ok. i am probly going to go with them when i get my comp ta-zrs.
-brian
1991 Camaro RS - Ultra Blue Metallic, T-Tops
GM 350 HO Crate Engine - Vortec Heads, Edelbrock Intake, Holley 670 CFM TB, Edelbrock Water Pump, March Pulleys, MSD 6AL, Blaster Coil, 8.5mm Super Conductors, Cap and Rotor, Rapidfires, Hypertech Fan Switch & Chip, SLP 1 3/4" Stainless Headers, 3" Cat Back, Flowmaster 40 Series
700R4 - 2,400 Stall Converter, Vette Servo, Shift Kit, B&M Super Cooler
GM 10 Bolt -coming soon Auburn Pro Series Differential, Richmond 3.73s
Brian's 1991 RS Central NY F-Body Association
Join the Third Generation F-Body TBI Web Ring
z28boy@twcny.rr.com IM name: Z28 Boy
-brian
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
255s all around and they only rub the plastic fender liners when I turn the wheel to lock.
not something I do over 5mph
How are you guys running 245's and 255's on the front when my 235's are rubbing on my sway bar? Are you using a differnt amount of back spacing? I would really like to know because 235's aren't really cutting it right now
. Thanks.
. Thanks. I've got 255-50-zr16 all for corners front only rubs on the front plastic inner fender a little when I turn the steering wheel lock to lock.
Camaroguy99, if your car didn't come with 245-50-16's on it the steering stops are set further in and let you turns the wheels more.
Car: 04 GTO
Transmission: M12 T56
Hey camaroguy, something doesn't seem right if your 235s rub a lot. All of the Z rated 16" tire thirdgens came stock w/ 245/50/16s.
As for me, like the others, my 245/50 fronts rub a little in full lock parking lot action, but they are a pretty wide 245. 255s in teh back are fine.
...ed
Ed Maher - Moderator @ The Carb Board
92 Z28 Convertible - Quasar blue / Tan top
LB9 4L60 GU2 G80 - stock, soon to be sleeper
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
...ed
Car: '84 Fiero ('01 GA interior)
Engine: '96 4.0 Aurora
Transmission: '96 4T80E
255s front and rear on my Formula. A little rubbing on the plastic liner when turning lock to lock. I'm running stock 16" GTA wheels with stock ride height.
91 LO3 has 245/50 r-16's no rubbing at all, car craft ran a guide on how to soup up 82-92 f-bodys, you can go 255's on the front w/o rubbing and with out a diff. offset. you can go 275's all the way around if you order rims with a custom offset (5.5" instead of 4.5")with the 275's they said they rub the tie rod going through slow long corners but if you have a good front suspension it shouldnt be a problem
1991 RS LO3
mods: 14" chrome air cleaner, straight-piped after cat exhaust with one chrome dual tip on the left side.
future mods: headers, removing smog equipment, and as many cheap mods as i can find
aol s/n: budman8503
1991 RS LO3
aol s/n: budman8503
damn 315? thats wider then my IROC!
im sold, if anyone out there has 335's/10/R20's tell me, ill fit them on my IROC asap!
Car: '92 droptop bird
Engine: 5.7L,mild cam etc.
Transmission: modded 700r4 w/2600
no prob,back in 89 when the formula was new we got a set of take-off comp t/as from a vette 255/50/16 all 4 for 300.00 killer deal they had 12mi.they provided 1.91 60' times and never rubbed..............
There won't be a problem running 255 up front. You won't run into any major problems until you increase the backspacing with different wheels. I wouldn't go any bigger than 265 on an 8" wide wheel, anoy more just buldges out too much. The 255/50/R16 is a good choice, but personally, I prefer to run BFGoodrich G-Force T/A KD or KDW tires, which only come as large as 245/50/R16. So I would stick with them on 16 x 8 wheels.
Car: '88 Firebird Formula 350
Engine: 350 (5.7 TPI)
Transmission: auto 700R4
Axle/Gears: BW 9-bolt L.S.
245/45-16 Front,
255/50-16 Back,
Looks great, no problems.
255/50-16 Back,
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Axle/Gears: 3.23 Posi
I have 245/50/16's on the front of my 89 T/A on GTA wheels. They rub when i turn it all the way. I remember reading somewhere that the cars originally equipped with 16 in rims, the gear boxes where different, something about how far they would go lock to lock.
Sorry,no digital camera, so no pics!
245/45-16 is quite common on fast cars overhere, like Porche's and Ferrari's, so I got Pirelli P-Zero at the front, and the 255/50-16 is originaly a Corvette dimension,and is also well available overhere, 245/50-16 is VERY rare here!!
(BTW I got Cooper brand).
The front of the car is slightly lower, and the back slightly higher than stock, all in all it looks good I.M.O.!
New2Chevy
Sep 28, 2015 12:35 AM
