305 vs 350 knock sensor part numbers??
Old Nov 5, 2001 | 12:26 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I've gone through the archives and seen that everybody and their brother (me included) always says to change the knock sensor on a 305 to 350 swap. But, somebody on my board, along with Kevin91z seems to think that until 1990, the 305 and 350 TPI cars used the same knock sensor. Does anybody have information on this?
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
Custom Thirdgen Subwoofer Enclosures
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Nov 6, 2001 | 04:12 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
I know they are tuned to a different frequency because the bore size is different. The diff size bore makes a different sound.
You can have my knock sensor if you want.
1986 Iroc 305 small block chevy getting modded now for speed
Old Nov 6, 2001 | 05:00 PM
Jim85IROC's Avatar
Thanks, but I don't need your knock sensor. I've been well aware that 350s and 305s use a different sensor, but it's come to my attention recently that for the TPI cars, they actually carry the same part number. I'm just trying to find out whether there is truth to this.
The IROC Homepage
Old Jan 19, 2003 | 06:49 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
back from the dead, i'd like to know too
Old Jan 20, 2003 | 12:30 AM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
Jim, they dont carry the same P/N. The autopart stores are WRONG. A while back, I purchased a KS for my 92 Vert. Well, turns out that they gave me the wrong sensor. In 90, GM switched to a 3.9k Ohm KS as opposed to the old style 100 Ohm one. Well, none of the parts stores knew about this, and all had the same one listed. I finally found a local non-commercial parts store who had the correct one... I just brought my Volt meter to make sure it was the 3.9 instead of the 100.
Old Jul 21, 2016 | 12:42 AM
Brian75's Avatar
Re: 305 vs 350 knock sensor part numbers??
Hi, well a lil to late for you all, but i do have the answer to this question for further help, im doing mine right now and i can say the part number for the 305 is 213-325 and for the 350, its 213-324
1992 Trans Am
May 10, 2023 07:19 PM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
st.evel07
Aug 13, 2015 06:15 PM
armybyrd
Aug 10, 2015 09:23 PM
1nastygta
Aug 8, 2015 07:38 PM
