4Gen T-Top Holder Upright
Car: 1992 Camaro RS
Engine: 305 V-8
Will the 4th ngen ttop holder which holds the ttops upright work with 3rd gen tops. Those look so much easier to store the ttops than the ones we have.
Car: 1992 Camaro RS
Engine: 305 V-8
Thats actually not a bad idea but I just don't think it will look good. Does anyone actually know if the 4th gen ttop holders will work or not??
Car: 92 Z28
Axle/Gears: 3.73 10 bolt
i dont think it will fit properly but you could probably mod it without much difficulty, 4th gen ttops are shaped differently and the front is rounded
Car: GM & Jaguar
Engine: Various
Transmission: Various
Axle/Gears: Various
Like I said... IF... you're serious
BTW by all means please don't tell the particular thread starter of the link above how you feel about the looks... it's become a touchy subject
Car: 1991 Z28
My advice? Bite the bullet and exert the tiny bit of effort it takes to carefully insert the t-tops into the bag. The bag works. It freakin' works!
Car: '99 HO Z28 / '03 Trailblazer
I think that the people who actually like using the bag are in the minority.
Here's my idea. Its still rough, but I only spent about 2 minutes thinking this up:
The bottom part is a metal plate in this shape: |_____|
It goes UNDER the carpet at the bottom of the well (welded in place) the uprights stick out thru slits in the carpet. You drop the T's down into the well, push down the handle that extends the pins into the uprights...then slide PIPE INSULATION (the tube shaped things at the top) on the glass ends of the T's to keep them from rubbing each other.
No glass flying forward under braking. No 2x4. No Fur. No problem!
Car: 1992 Camaro RS
Engine: 305 V-8
87-black-ws6 thats a really good idea. Alote better than the 2x4. Its really got me thinking.........I might just have to try that out.
Car: 1991 Z28
Originally posted by 87-BLACK-WS6
If it worked so well, wouldn't they have re-used the idea for the 4th gen cars?
But it isn't that the bag doesn't work, it's just Americans are so bloody fast-paced (read: lazy) they don't want to take the time it requires to neatly place the tops into the bag. They just wanna throw 'em in slots and be off!
Just my preference, I've seen both in action and I firmly trust the bag over any sort of custom contraption - even the 4th gen holders.
I remember my last t-top car. When it was new those tops were off at every opportunity. Once I was already used to it, I wouldn't take them off unless it was a long enough trip. That was with just tossing them in the well since my '93 TransAm didn't have the T-top holder for some reason.
If you could leave the tops off while you go into a store and trust that some asswipe won't toss trash (or worse) into your car while you were in there...then the bag becomes more viable.
I know what you are saying, and I agree to a point, but I dont think it's just people being lazy.
Car: 1991 Z28
Car: Yellow/Black 1987 Z28
Engine: 355 Carb
so i guess im a quick t-top into the bag person if i can get mine in there in under a minute and a half huh? awesome new bragging rights!!!!:lala:
Car: 92 Z28
really whats wrong with the 2x4 ...I think it looks good..
I drove my sisters 95 firebird for a few weeks and really like taking the ttops off and just throwing them in the trunk, its really easy.. but then again I dont even have ttops
Car: 1991 Z28
Car: 88 Trans Am
Engine: 5.7 TPI
I agree with the bag being generally inefficient. Most of my trips are very short and involve running into various stores. It gets to be a real hassle to remove and store the tops every few mins. This is why I have 4 sets of tops. A good and a not-so good set of plastic and glass. On most of my daily commutes and errand-running, I usually use my toss-around set of plastic ones, so that I can quickly and easily either store them whether I decide to use one of my bags, the well, or my back seats
I have never seen the 4th gen holders "in action", but I am thinking that it is a generally better storage method to begin with.
Look at how glass is stored and transported....Upright! You lay glass down flat and it's more likely to break. The ttops bag and carpet provide a little padding, but then you also have the weight of the other ttop on top of it. Using a bag instead of an upright system is more likely to stratch the ttops as well. It's just so damn awkward to put them in like that. It takes forever to do it right.
Car: 1991 Z28
I suppose I'm the only one....but I don't know, there's just something about the bag I find awfully grand.
Car: 1986 Trans Am
Engine: 305 LB9 TPI
Transmission: 700-R4
did i post my idea or did he steal it. I just went to home depot to buy some metal for this. Man i shoulda patented while i still had the chance.
That was relaly what my idea with the 2x4 transformed into. But the 2x4 will still be there but it will be removable, and the locking mechanism at the bottom will be bolted down. Its gonan look very nice, but i gotta finish the rest of the interior mods....
shane
shane
Car: 92 Z28
shane
shane
Car: 92 Z28
Dude maybee you could get some friends together and start making fur covered 2x4's for ttop storage.. you'd have to get that patent first so no one could steal it tho...
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
I've always stuck my tops in the back seat... seemed the easiest solution and keeps from having to dig in the hatch every time you want to store or remove your tops.
Car: 1982 Pontiac Trans Am
Engine: Stock carbed 305
Transmission: Stock 200C
Engine: TPI 305/ v6
the sun hit one of the tops perfectly that it focused a reflected beam of light right on my passenger sun visor and started to burn a hole in it
Engine: 305 tbi=LO3
Transmission: Automatic
ha, my bag sure doesnt work, its all dry rotted along the zipper, so that when i try to sew it back together it just rips again...............thats why i made an upright, im going to be making another pretty soon.(1st left some to be desired)
Car: '00 Chevrolet Corvette
I hate the bag. I've had the zippers break (replaced with key-rings) and then I've had a whole bunch of the zipper teeth break rendering the first five inches of the drivers side of it useless. I guess one day I'll buy another one, unless I figure out another good way to store them.
Car: 1991 Z28
So, more accurately, you bag would work if the previous owner had put forth the effort to protect the bag from the elements.
Car: 1991 Z28
I've been through many bags and all have functioned perfectly within the parameters GM intended them to perform under. I hope if you're able to come across a well-maintained, crisp t-top bag that you just might change your opinion.
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
BirdsOfPrey, were you the original designer of the t-top bag?!? LOL, I've never seen someone defend a product as strongly as you have. My TA didn't come with a bag when i bought it and I'll be working on an upright storage system also.
Car: 91 Firebird
Engine: 191ci 6cyl
I personally have no problem with the bag right now....I ran into a snag a yr ago when I put subs in the back but I just moved the clamps that were next to the hatch motor onto the back of the rear seat so you fold the seat down and secure the bag to that then your off, granted you can't fit many people in the car with the tops off but they're off, I get my subs and amp, all works good. Just use the bag, it's a lot better then any slot setup that could risk loosing a t-top.
Side Note...Always make sure to lock the t-tops when you put'em back on, they come off at 90 - 100mph on the highway and get good air, thank *** there wasn't a car behind me.
Car: '86 Trans Am
Engine: LG4
Axle/Gears: 3.70 Posi disc 9 bolt
Okay, now that the ttop's have a new storage place for quick removal, how do they react in a traffic accident?
Let's say your doing 45-50 mph on your favorite street and you happen to T-bone a Dodge Ram who ran a stop sign on your right side.
Here come to guinsu knives from the rear headed for the back of yours and the passengers heads. Shhwiiing!!
With the bag and provided storage lines/clips I guess they may tend to stay in place. I'll spend the couple of extra minutes and not loose my head.
Anyone crash tested this new storage location?
Jim.
Jim.
Car: '86 Trans Am
Engine: LG4
My wife probably wishes I would.
Where u located? I just moved to Universal City. Still haven't found a group to meet with here in SA.
Jim.
Jim.
Jim.
Jim.
Car: 1986 Trans Am
Engine: 305 LB9 TPI
ummm guys what happened to the board, am the only person seeing it completely different boards? I think the new design is stupid and we should revert to the old one. What happened?
Shane
Shane
Car: 88 Trans Am
Engine: 5.7 TPI
Hmmm....crash safety....Didn't think of that one. The ttop bag is going to be safer. However, the upright storage solution was supposed to be designed for short trips as an alternative to throwing the tops in the back seat or on the back edge (which is really dangerous) So, having the upright storage is safer than noting at all.
Car: 91 firebird now
Transmission: 5 speed
I always use the bags, with my driving I love to have them tightly secured down so when I go around a corner at high speeds or have to slam on the brakes I know my t tops are safe and are not going to come smashing into my head or passanger or break, Ive never had a problem with the bag sure it takes a minute or 2 more but to know they are safe and that I can drive as wild as I want without fear of them doing any damage to them selfs or me is assuring, both my trans ams had t top bags with the zippers and I love the bags unless I could build a case to go in the back that was molded to the tops with a locking top or bar system that would keep them from moving 100% then I will still used the t top bag and such a case would take up alot of space when the t top bag is out of the way when not being used. Just my 2 cents I love to see the ideas about storage but have yet to see one I like better than the bags so keep working guys.
Moderator/TGO Supporter
Car: 1997 Z28
Take it from someone who owns both a third and a fourth gen. The third gen style is way easier to use.
And with the fourth gen setup, you lose whatever little storage space you may have had with the tops out.
My advice, use the bag, the 4th gen design is not all its cracked up to be.
Car: 1991 Z28
Definitely nice to see some fellow admirers of the t-top bag. I had almost forgotten my vehement defense of it in this thread, slightly amusing to come back to it after a few months.
I mean, I really like the bag.
Car: '86 Camaro
Transmission: ..auto =D
hmm
I've been hoping for an upright thirdgen solution for a while now.. bleh. A 2x4??
I thought about it, and the thing with upright storage is that you can just drop it right in. I mean.. Now that summers here, I take the t-tops off every morning and put them on at night. The flimsy bag catches on the glass, drags all over the place.. can't get it in, and even when I do, the blasted zipper is screwed up. On top of that, some label in my bag came off and left a bunch of sticky sh*t! Grr! So I was thinking.. maybe make a hard horizontal enclosure that's hinged and padded. Like a clam-shell with a divider. You open it up, slide the tops in, and close it. I was thinking about this when I saw the pneumatic shocks keeping the hatch/hood open. Now if only I was some sort of craftsman..
Thirdgen89GTA
Nov 26, 2015 11:04 PM
gta892000
Sep 16, 2015 12:37 AM
