My 1991 Camaro
Old Oct 12, 2003 | 11:01 PM
BirdsofPray's Avatar
Car: 1991 Z28
My 1991 Camaro
Here are a few pics of my Camaro. These were taken in June, after I took this car all the way to Panama City, Fl. Sometime in the future I'm planning to fix the scratches in the front ground effect....I went a little into a ditch all over a suicidal possum. Not that I'm angry about it, I cannot justify killing something just to save the cosmetic value of my car. But, I digress, let me know if you have any suggestions I could add to my car.
Old Oct 12, 2003 | 11:06 PM
Buck268's Avatar
Re: My 1991 Camaro
How about my name to the title?
Old Oct 12, 2003 | 11:07 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
Sweet Z28 :hail: Thats a very clean engine compartment.
Old Oct 12, 2003 | 11:18 PM
Sonar_un's Avatar
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
I was thinking the same thing.. freaking awesome!
Old Oct 12, 2003 | 11:22 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
how big was the possum? Would bet from the tiny amount of damage on the car that hitting the possum probably would have been worse.
Old Oct 13, 2003 | 12:09 AM
Error404's Avatar
Car: 86 Iroc
Engine: 350 crate
Transmission: built 700r4
yes, nice looking engine bay :-)
Suggestions?
Well, I personaly don't like the wing type spoilers, I like the lower ones that just "lip up".
Also, the front blinkers look very old compared to the headlights and the rest of the car. maybe clean the inside of them or something.
Old Oct 13, 2003 | 12:52 AM
Car: 1991 Z28
That's a good point, 19doug90, because it looked about the size of a raccoon. My former boss got a huge dent in the bumper of her Eclipse from hitting a skunk.
Thanks the the suggestions, Error404, I definitely need to clean up the blinkers a bit. I've been meaning to get around to that, as well as replacing the lights. The former owner put in red bulbs which I'm personally not too fond of.
I guess you could say I agree with the "less=more" concept myself.
Old Oct 13, 2003 | 07:55 AM
05kcilS's Avatar
Car: 1991 Z28
Engine: 350 L98
stb, maybe some tint. new parking lights, get the clear turn signal reflectors.
Old Oct 13, 2003 | 08:17 AM
86FyrBrd's Avatar
Car: 1992 Camaro Z28 Convertible Z03
Engine: 383 SuperRam
Nice! My car with T-Tops and a 305
Old Oct 13, 2003 | 09:44 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
True sparkplug wire holders/retainers rather then tye wraps. Also, remove the dual snorkle if your going to keep the filter on the engine like that. Part to replace snorkle should be easy find.
Hey, look at this, I got one in my garage
Old Oct 13, 2003 | 10:16 AM
91Zman's Avatar
Car: 1991 Z28
Transmission: 4L60 automatic
Very nice!:hail:
Old Oct 13, 2003 | 10:17 AM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
something thats probably more superstition then fact with todays wires but its not the greatest idea to bundle all of your wires together just because its always possible a spark could jump wires. The way i did it was okay take the first two wires, put a tie wrap around each loosely and then tie wrap together the two tie wraps then tighten it all up...snip the excess off and it looks descent and is functional because it keeps the wires apart
Old Oct 13, 2003 | 12:33 PM
Car: 1991 Z28
Thanks for the suggestions on the wires, as you could probably tell I was a little hazy on how to get them out of the way and properly secured!
Old Oct 13, 2003 | 12:41 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
np i had a friends dad tell me how to do it so the info just gets passed down...the only thing i left out is that the last wire just gets wire tied down to anything not too hot that will hold the whole row out of the way....if you do it right (i didnt but i did it functional enough so i dont care) it serves its purpose and actually looks kind of good. Yay for a home made spark plug wire loom.
Old Oct 13, 2003 | 12:49 PM
FyreLance's Avatar
Car: 00 TA, 91 Formula, 89 RS
Gorgeous
Old Oct 13, 2003 | 01:34 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
Awesome Z28... I suggest you trade ground effects with me though
Old Oct 13, 2003 | 01:58 PM
nolanr0413's Avatar
Car: Trans am
Old Oct 14, 2003 | 07:15 AM
Z dude's Avatar
Car: 1991 Z-28
Engine: TPI
Transmission: 5-speed Rear:3.73
did someone take the red off the inside of the rims?
and what are they now black in there? Cant quite see..but nice car
Old Oct 14, 2003 | 11:32 AM
badandy247's Avatar
Car: 91 Camaro RS
Engine: 3.1L V-6
Transmission: Fresh 700R4
i don't think that there ever was red inside the rims
Old Oct 14, 2003 | 11:35 AM
Z dude's Avatar
Car: 1991 Z-28
Engine: TPI
my 91 is red in there and all the others Ive seen are too
like this..
Old Oct 14, 2003 | 11:38 AM
badandy247's Avatar
Car: 91 Camaro RS
Engine: 3.1L V-6
that was an option that not every car had i belive you could get plain aluminum, black, or color matched to the body
Old Oct 14, 2003 | 11:40 AM
Z dude's Avatar
Car: 1991 Z-28
Engine: TPI
I wish mine was plain yeah I was wondering if that would look better black than red?
Old Oct 14, 2003 | 11:42 AM
badandy247's Avatar
Car: 91 Camaro RS
Engine: 3.1L V-6
you could strip and paint them and even polish them while you are at it your wheels are the easiest factory wheels to polish and they look awesome polished
there is a tech article on it and several members have done it recently
Old Oct 14, 2003 | 11:43 AM
91Zman's Avatar
Car: 1991 Z28
My Z had red on th ewheels too but I stripped the paint off cause they turned pink.I think(not sure) that only the 350tpi Zs had painted wheels.
Old Oct 14, 2003 | 12:33 PM
Z dude's Avatar
Car: 1991 Z-28
Engine: TPI
thats exactly whats wrong with mine!!!!!!!
I dont care for pink on my car so I need to do something.....what did you use....aircraft stripper? and after they were stripped did you just leave the aluminum look? thanks
Old Oct 14, 2003 | 12:40 PM
86FyrBrd's Avatar
I think they look better red, take them off, tape off the smooth outer lip paint the entire rim, and use a sander on all the flat parts, keep sanding till smooth.
Old Oct 14, 2003 | 12:50 PM
91Zman's Avatar
Car: 1991 Z28
Yeah I used the aircraft stuff but in the spray can plus a small wire brush.It took all of the clear of and most of the faded red too,the rest I had to use the brush with the stripper.I would repaint my wheel red again but they are badly knicked up and road rashed.So I plan on getting a new set.
Old Oct 14, 2003 | 05:38 PM
Z dude's Avatar
Car: 1991 Z-28
Engine: TPI
well......after looking at that 91-Z I figured I liked that look better ....so I started to strip mine today! DAAAAAAAAAAMN it sucks.....I got one done so far lol
Old Oct 14, 2003 | 05:55 PM
91Zman's Avatar
Car: 1991 Z28
One word of caution,don't get any of that stripper on any part of the tire or any plastic.The stripper will discolor the tire and kinda melt or cloudy plastic.
Old Oct 14, 2003 | 06:02 PM
Z dude's Avatar
Car: 1991 Z-28
Engine: TPI
Im just glad it dont eat rubber.....my motorcycle tire would have fell apart I got so much on it when I did those rims
the Z rim looks pretty good but there is still a hint of red in places...howed you get all the pink off your rims without scratching the hell out of the good aluminum around it ??
Its gonna rain here tomorrow,after that I'll get some pics
Old Oct 14, 2003 | 06:12 PM
91Zman's Avatar
Car: 1991 Z28
I used one of those little red wire brushes that you use to clean off battery terminals.I sprayed the stripper on,wait a few seconds and then scrubbed that area with the brush.I also used medium/fine grit sandpaper along with the stripper for the areas where the paint was hard to get off.After I was done I quickly washed off the stripper residue before it dried on the wheel.
Old Oct 14, 2003 | 06:18 PM
Z dude's Avatar
Car: 1991 Z-28
Engine: TPI
ok thanks..thats pretty much what I was doing,but I was using 0000-steel wool
Old Oct 14, 2003 | 06:20 PM
BLURR's Avatar
Car: 1989 Iroc Z
Engine: 5.7 TPI
Sweeet looking Z man.
Old Oct 16, 2003 | 07:32 PM
Z dude's Avatar
Car: 1991 Z-28
Engine: TPI
well thanks too BirdsofPray after looking at his rims on his 91
I fingered I should strip my red faded to pink rims...
Before
After
Old Oct 16, 2003 | 08:00 PM
91Zman's Avatar
Car: 1991 Z28
Looks like like it came out pretty good Zdude.
Old Oct 16, 2003 | 08:13 PM
Car: 1991 Z28
Wow, very nice Z dude!
Old Oct 16, 2003 | 09:47 PM
Z dude's Avatar
Car: 1991 Z-28
Engine: TPI
thanks,but one thing....how can I get into that little line that goes around the inside of the wheel better? It still has a little pink left, its hard to see unless your up close looking but I know its there and its buggin me
Im sure you know what little line I meen...its the ring that runs right through the valve stem...any ideas? I put the stripper right to it but it just wont get it out
Old Oct 16, 2003 | 10:18 PM
Pew's Avatar
Pew
Car: 90 camaro
Transmission: t10
Axle/Gears: 9" with 4.88's
nice clean car ya got
Old Oct 17, 2003 | 10:28 AM
91Zman's Avatar
Car: 1991 Z28
I know that bugs me too about mine,have yet to figure how to get rid of the paint without scuffing the wheel....dremel maybe?
Old Oct 17, 2003 | 10:49 AM
Z dude's Avatar
Car: 1991 Z-28
Engine: TPI
yep...tryed the dremel too haha
I guess I'll just have to live with it..
either way its waaaaaay better than pink,people saw the pink and said why did you paint them rims pink...Im like thats cause there faded,and they look at me like they never heard of that
Old Jul 4, 2005 | 10:07 PM
DanTheMan_smlk's Avatar
hey, really nice car, i love the interior! BTW whoever is hosting your pics is doing a sh1tty job....ever try photobucket, i think they still allow free accounts
Old Jul 5, 2005 | 03:17 PM
87_350's Avatar
Car: 87 firebird formula
Engine: 350 sbc
Sweeet car man!
I got one question for ya, where did ya get that air intake filter at?
Old Jul 5, 2005 | 03:26 PM
Gr89RS's Avatar
Car: '02 Z06
This thread is almost two years old
Nice car anyways!
Old Jul 5, 2005 | 06:37 PM
Car: 1991 Z28
Yes, it's an old thread, actually my first, but I appreciate the comments nonetheless. The car still looks the same aside from some paint touch-up and the problem with the wires in the engine bay has been corrected.
I've been using Sony Imagestation to host, simply because it's free and I don't use it enough to warrant paying for it. I'll definitely check out photobucket though. By the way, if you're interested, I still have the hi-res pictures here and a few others I can email.
I bought that air filter at the local O'Reilly's here a few years ago. They had to special order it, not because it's an especially unique part, but rather because the auto shops here have the strange habit of only stocking the parts no one needs.
jhawkeye
May 25, 2022 06:33 PM
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
Cripley
Aug 17, 2015 03:35 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
