Griffin 31x19 and FlexALite 210 Fans
Old Jul 18, 2005 | 07:35 PM
Kevs87Z28's Avatar
Car: Yellow/Black 1987 Z28
Engine: 355 Carb
hey guys. just wanted to say i got a griffin radiator and flexalite fans this weekend and installed them today. very pleased with the setup. the radiator is the 31X19X3 with dual 1 inch rows. the fans are flexalite 210 dual pullers.
the install was super easy. no modifying other then making my own upper radiator support. also got a flex hose for the bottom and a L shaped hose to tie into my intake manifold for the heater core. this radiator doesnt have a trans cooler, petcock, or heater fitting.
pics will be posted tonight after i upload them to cardomain.
Old Jul 18, 2005 | 08:24 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
same setup I have. Does a great job. !!
Old Jul 20, 2005 | 07:02 PM
EndlessSummer85's Avatar
Car: 1982, 2000 Trans Am
Engine: 350 bored .040 over: LS1
Transmission: Borg Warner Super T-10: Tremec T-56
Axle/Gears: 4.10s; 3.42's
What did you do to make your own upper radiator support? I currently have the same fan setup on a stock radiator and have been contemplating on putting in a griffen 31'' x 19''. Any help would be appreciated.
Old Jul 21, 2005 | 06:49 AM
Anniversary-Z-man's Avatar
Car: 1992 25th Anniversary Z28
Engine: 6.3L - 383
Transmission: 700R4; Vig 3200
I've got the Griffin 31x19 installed with the factory dual fans right now as well....just use a dremel to slightly mod the upper rad. support to fit the new rad. tightly.
Old Jul 21, 2005 | 08:55 PM
Kevs87Z28's Avatar
Engine: 355 Carb
i made one out of an aluminum sheet. then used a piece of foam i got from wal-mart to pad it and hold it really tight. works great!
Old Jul 25, 2005 | 08:31 PM
bluegoose's Avatar
Car: Firebird
Engine: 383
Transmission: 700R4, lots of Mods
Can you please post the pics, I am in the maket to put a new radiator in and I been told that griffin is the best.
Brad
Old Jul 25, 2005 | 10:09 PM
Kevs87Z28's Avatar
Engine: 355 Carb
anything more specific??? let me know i can try to get anything u need.
Old Jul 26, 2005 | 07:05 PM
Looks Good!! Did you modify the lower radiator support any? Kind of hard to tell from the pics.
Old Jul 26, 2005 | 09:42 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Kev do you mind sharing how you created that? It looks very nice. I need something to hold my C&R up.
Old Jul 26, 2005 | 09:50 PM
Forshock 85TA's Avatar
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
Looks nice, most of you need to note that the fans are installed with the "through the radiator" ties. That is a nice clean install though. I like the upper mount
Old Jul 27, 2005 | 12:31 AM
Kevs87Z28's Avatar
Engine: 355 Carb
the lower support remains unmodified. i made the mount myself i plan to make more and polishor paint them to maybe sell on here since people are really getting into installing this radiator.
the fans come with some brackets but it was easier/faster to just stick the things through the fins. be careful with that though the fins and the plastic things are easily tore up or broken.
fans came with the wiring, the brackets, the ties, and a probe/control box. i bought more wiring to make the install as clean as possible.
Old Sep 16, 2005 | 07:10 PM
Well I finally bought my Griffin radiator. Any tips for the install I plan on doing it tomorrow. Also what temp do you have your fans set for? or do you have the fans running all the time?
Old Sep 17, 2005 | 08:22 PM
Install was a snap, made two brackets to hold the radiator in place doesn't look as good as kevs does tho. Performs excellent, driving down the highway running at 180-185, and starts to cool almost immediately when idleing. Kev if you do make any of those upper supports to sell let me know.
Old Nov 20, 2005 | 08:46 PM
GarageToys's Avatar
Car: 89 Iroc Hardtop
Engine: LB9 w/G92 Pkg
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt, 3.45
Nice top plate. I just bought a Griffin radiator and will need to make one like that. I'm going to be running dual Spal fans, but I'm going to mount them with brackets. IMO, dual electric fans are too heavy to mount with those ziptie things-- you're just asking for problems.
Old Nov 20, 2005 | 09:04 PM
Kevs87Z28's Avatar
Engine: 355 Carb
thezipties work fine. i have had it over 120 mph since and they havent flew off or anything. still running cool with no probs. i have my temp at 190 ish. i let the radiator do most of the work but if you sit for a few the fans come on. radiator supports to sell is a project im going to start in the spring. good luck all...
Old May 16, 2006 | 05:27 PM
327 camaro's Avatar
Car: 87 IROC
Engine: 327
Transmission: tremec t56
Axle/Gears: posi 3.23
Also have Griffin 31"x19" radiator but still runs a little warm. Wondering if a dual fan would cool my motor a little more bc its bored 40 over?
Old May 16, 2006 | 05:56 PM
Car: 85 Trans Am
Just because the rad is "bigger" doesnt make it cool, it just makes the potential cooling better.
What thermo, fans(mech or elec?), etc.? There are a lot of variables.
Stock dual fans didnt work for me with my northern (same size)...
Old May 16, 2006 | 06:13 PM
327 camaro's Avatar
Car: 87 IROC
Engine: 327
My thermostat is 195, Mechanical fan and I was thinking of ordering dual fans from summit.
Old May 16, 2006 | 06:16 PM
Car: 85 Trans Am
What is "warm"?
with a 195, 220 wouldnt sound far off. When cruising (highway) what are the temps? stop and go? idling?
Remember the air dam of course. Shroud in place? maybe search a little more, if not start a new thread...
Old May 16, 2006 | 06:42 PM
327 camaro's Avatar
Car: 87 IROC
Engine: 327
Just went out to car and my air dam is gone so i will get another and if that doesnt fix it I will just have to do more research.
Old May 17, 2006 | 11:46 AM
I have this setup on my 82 which has a 350 punched out .40 over. I'm running a 160 thermostat, and it stays at 180-190 going down the high ways and will cool down to 160 when ideling. Def start by replacing the air damn, that will prob drop your cruising temp by 10 degrees. Hope it works out for you!
Old May 17, 2006 | 06:32 PM
327 camaro's Avatar
Car: 87 IROC
Engine: 327
Think a 165 thermostat would help with the air dam?
Old May 17, 2006 | 06:58 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Worry about the air dam first.
Old May 17, 2006 | 10:47 PM
Yea I would definately get a new air dam, you can get one off of YearOne.com they're not expensive and easy to install. I would put in a 160 or a 180 thermostat especially with summer on the way. Also I saw that jegs has a 31x19 universal with an electric fan and full shroud with the adjustable temp box, also has a catch can. Anyone use one of these with any succees??? Price looks pretty good at $422.
Old May 17, 2006 | 10:53 PM
Car: 85 Trans Am
That fan shroud would be fine for a "race car" type setup. however i dont think (not pro here) but the small fan would most likely not be able to pull enough air. if it was a spal or Zirgo fan then maybe.
and for $200 you could get a dual spal setup. so that comes out to roughly the same price $400 or so.
Old May 17, 2006 | 11:05 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
I think what he's talking about is this:
JEGS High Performance - Jegster/Flex-a-lite Universal Radiator Systems
If so, that's hardly "race class." Looks pretty effective, actually.
Old May 17, 2006 | 11:12 PM
Car: 85 Trans Am
there are no specs on the fan.... most likely a 16", so 2300cfm +/-
At highway that single fan hole will be a restriction. I have the thunderbird/taurus fan and it is a restriction at highway speeds, doesnt cool as fast as before. it only covers 7/8 of the radiator.
Old May 18, 2006 | 11:44 AM
Yea stekman thats the setup I was talking about. I'm currently running a
31x19 griffin with the 210 fan setup, I peiced it togather and paid more than the jegs setup. I was just curious if anyone here has run em. I originally had the 210's on a stock radiator, and that wasn't getting the job done, so i bought the griffin, runs were it should be now.
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
BrianI
Oct 3, 2015 12:57 PM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
