Whole slew of things....
Old Apr 16, 2003 | 10:22 AM
Doward's Avatar
Hey guys (and gals) just a quick update on my car, then I gotta get back to working on it.
Last night I removed the AIR (smog pump) assembly, and the EGR. No codes thrown (odd??). I also cleaned the IAC, but now my idle is hunting BIG time (500rpm-3000rpm) but I can also hear the hiss of a vacuum leak - all that damned plastic tubing is about to get ripped out, and replaced with HOSE.
REAL RUBBER I-WON'T-BREAK-WHEN-TOUCHED-HOSE!!!
When i get the leak taken care of, then I'll work on the idle.
Heh... also, pulled out the air silencers under the air filters, and instead of cutting holes, I cut out the boxes themselves, and pulled out all that plastic underneath it. Car makes a cool swooshing sound now :P So lots more air being injested, less rotating resistance (smog pump delete) and less weight (smog pump + egr + everything else :P) Sounds like my 17.07 SHOULD be a 16 second now! I hope so... we'll find out in a couple weeks, when next I run the track.
And for anyone wondering, OMG. IT IS SO FREAKING EASY TO CHANGE THE PLUGS NOW!!
Lemme go get the camera, I'll show ya'll...
Old Apr 16, 2003 | 10:39 AM
Doward's Avatar
Engine Compartment:
Doward's Avatar
No EGR!
Old Apr 16, 2003 | 10:40 AM
Doward's Avatar
No AIR (smog):
Doward's Avatar
New Belt:
Old Apr 16, 2003 | 11:53 AM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
Might I suggest some Simple Green on that passenger side valve cover?
Old Apr 16, 2003 | 01:02 PM
Doward's Avatar
rofl - I'll do an engine clean later down the road...
:lala: :lala: :lala: :lala:
*for my Fiance, don't ask*
Old Apr 16, 2003 | 01:36 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Was that the digital egr type, or the gold ufo type??
Yes, engine clean up is a must!!
Can I get pic of whats left of the TPI intake lower section
Old Apr 16, 2003 | 01:48 PM
Doward's Avatar
lol, sure, gimme a couple seconds... I just broke that damn IAC valve. Yay. Time for a new one!
Old Apr 16, 2003 | 01:50 PM
Doward's Avatar
Straight EGR, btw - no digital. Digital was on the 3.1s
Old Apr 16, 2003 | 01:56 PM
Nixon1's Avatar
Wow..it looks so....clean.... Beautiful man, simply beautiful.
How the heck did you manage to break the IAC valve?? Lol, just wondering... No BIGGIE...just another $25-$30....but then a new valve will operate better than an old cleaned one, so....
Hope it runs good once ya get everything fixed up...sounds like a sweet deal to me!
Old Apr 16, 2003 | 11:15 PM
Doward's Avatar
How did I break it? It's FRIGGEN PLASTIC. It's ok - the new one is metal.... ahhhh.... no worries of breaking it there!
I'll get you guys pics tomorrow of the new improved intake
Old Apr 17, 2003 | 08:54 AM
KED85's Avatar
REMOTE MOUNT COIL!
You have a stick set up right?
Attached Thumbnails Whole slew of things....-coil-20up-20-26
Old Apr 17, 2003 | 09:19 AM
funstick's Avatar
do your self a favor and swap that upper pleunum halve and the TB for the later 3.1 uper plenum and the TB. it deletes that whole vacum leak cuasing POS plastic IAC tube. then just plug it off at the back.
Old Apr 17, 2003 | 09:30 AM
Azure's Avatar
From: "No one cares if you're in before the lock!" - Best quote ever.
How does one go about removing the EGR..? That's been a thorn in my side for awhile now...)
Old Apr 17, 2003 | 10:05 AM
Doward's Avatar
I'm thinking of writing up an article or two on some of this... maybe when I've got a little more time.
As for the plenum, I would, except I just got a nice, new metal IAC. No breakage there! My vacuum leak is coming from those plastic tubes... about to go out there, get a pic of the intake, then work on the vacuum tubing.
Old Apr 17, 2003 | 10:30 AM
Doward's Avatar
One more pic without smog pump
Old Apr 17, 2003 | 10:43 AM
Dale's Avatar
Engine: 350 S-TPI
Wonder how that would work on 3.1l, but leave the egr???
Old Apr 17, 2003 | 11:24 AM
Doward's Avatar
Just leave the egr... the biggest reason I did it, was ease of access to my wires!
Old Apr 17, 2003 | 09:58 PM
88CamaroKid's Avatar
Car: '99 Ranger (Need 3G)
Engine: 2.5L
Transmission: AOD
Hey, your engine bay looks AWESOME! Do us guys that arent in Cali really need the EGR and Smog pump? What exactly do they do? Cause if i can get rid of excess weight and stuff I don't really need.... I'll go for it! Let me know... I gotta start cleanin up my bay!
Old Apr 17, 2003 | 10:45 PM
Doward's Avatar
thanks for all the compliments.... don't let the pics fool you, it's dirty as can be in there! Got all teh vacuum leaks taken care of.. Running much better now! Next is a distributor rebuild...
Old Apr 17, 2003 | 10:50 PM
Nixon1's Avatar
Do you need that stuff in Cali.. Ha ha... Funny question. YES!!! Otherwise your emissions will be so high it'll blow up their machine. :P EGR and smog pump are both major emissions equipment, especially the EGR.
Old Apr 18, 2003 | 12:12 AM
bes217's Avatar
My car doesn't and never did have a smog pump and I live right in the heart of California. But, I do have an EGR. It passes smog just fine!!
Old Apr 18, 2003 | 03:05 AM
vortex's Avatar
Car: 95 Mustang GT Vert
Engine: 5.0
Hey D-man, don't forget to point out who showed ya the air silencer trick.. as many im sure would call it, an enemy from a different "stable", but as far as im concerned, domy's gotta stick together.
~*Import Slayer*~
1995 Mustang GT Convertible
Crane HI-6S Ignition box w/ fireball coil
3.55 FMS gears
BBK Cold Air induction
Tri-Ax Short Throw
Steeda: G-Trac with X2 BallJoints, Bumpsteer Kit,Tokico 5-Adjustables
Old Apr 18, 2003 | 10:34 AM
Doward's Avatar
~*Import Slayer*~
3.55 FMS gears
Tri-Ax Short Throw
rofl... yeah, I edited that part out. My buddy Vortex there of the Mustang persuasion showed me that trick.... even he couldn't believe how restrictive the intake was!
Old May 9, 2003 | 11:03 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
does unplugging the smog pump (electric hook up) have any adverse effects on the computer? i have all the stuff off of the back of my smog pump wire tied in there so i could still plug it in. the whole assembly would not fit with the headers. also, i am running no egr, again because of the headers, and occasionally get a code from the computer. it is gone next time i go to drive the car though.
Old Aug 1, 2004 | 06:55 PM
crazy3rdgen's Avatar
Car: 2002 SS
Engine: Ls1
Axle/Gears: 3:42 posi
hey
what size pully am i going to need if i delete my a/c compressor. i know im going to need a 91.5" belt. Because i am taking out the smog also.
sean
Old Aug 1, 2004 | 08:10 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Am I the only one that didn't have an smog pump on a 2.8?
Old Aug 1, 2004 | 10:16 PM
Doward's Avatar
I need an icon of a post rising from the dead.... j/k!
No idea - best way to do it, is to get the pulley you want, bolt it in, and then measure for the belt. You'll need whatever size belt you come up with.. How did you figure 91.5"?
Old Aug 1, 2004 | 11:03 PM
GreyFox's Avatar
Car: 1991 Firebird
Engine: V6
Transmission: ATOD
i did all that removing on another car (which is also from a different stable) when i put on the new headers, the guys at the shop that put em on said that i would still pass inspection with out the smog pump being hooked up because there was no place for it on the new setup, however they were wrong, no one would pass that car, i sold it to a friend and some shops told him it would cost alot of money to make it pass emissions, which included removal of the headers and ordering a stock style manifold, so he junked the car, which sucked because i would have taken it off the yards hand but he told them to just kill it and they did, what i'm getting at is if you live in virginia DONT do what doward is doing and definately don't do it in cali they are worse than us
Old Aug 2, 2004 | 12:00 AM
Doward's Avatar
Is doing? It's been a done deal for some time now... Florida has no emissions!
Old Aug 2, 2004 | 04:15 AM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Again, we ask all folks to check the dates of threads they consider replying to BEFORE replying (this means you, crazy3rdgen). Digging up threads this old is totally unneccessary. A new thread would have been far more fitting.. and will now be required.
This thread *did* die 5/9/2003. Returned to the grave 8/2/2004. May it rest in peace this time.
MustangEater82
Members Camaros
May 25, 2015 03:41 PM
1983Zsled
Aftermarket Product Review
Oct 11, 2013 01:09 PM
dragsta
Aug 30, 2012 08:01 AM
