What are you electric speedo guys using when changing gears?
Old Nov 12, 2003 | 01:01 AM
25THRSS's Avatar
I'de like to know what everyone with a 90-92 tbi car is using to recalibrate their speedometer when swapping gears? Did you change the speedo gears or go with a buffer? Which would be better and why?
Old Nov 12, 2003 | 12:44 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I am not sure if you are a manual of auto but for manual you have to change speedo gears inside the tranny which requires you to drop it. here are my speedo gears for my 1990 T5. going from 3.08 to 3.42. I believe you change the auto ones from the outside.
Attached Thumbnails What are you electric speedo guys using when changing gears?-mvc-052s.jpg
Old Nov 12, 2003 | 12:48 PM
Dewey316's Avatar
Car: 1990 Camaro RS
that and the dakota digital box is the only options.
Old Nov 12, 2003 | 05:47 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
i changed the gears in the tranny, required removing the tailshaft.
Old Nov 12, 2003 | 06:08 PM
Kandied91z's Avatar
gotta love the ease of speed density. changed mine in under a minute on the chip.
Old Nov 12, 2003 | 07:10 PM
novadk13's Avatar
Car: 92 Firebird,74 Nova
Engine: Stock tbi,Vortec 350
Transmission: T56, th350
Axle/Gears: 3.73 LSD, 2.73 open
Is that a factory chip? I always thought you had to use the gears to get the spedo right? I plan on doing a posi swap this spring but I heard I didnt need to get those trans gears and that the computer will reset for the new gears, is that correct? I got a 92 tbi with the auto trans.
Old Nov 12, 2003 | 07:14 PM
Kandied91z's Avatar
i wouldn't know with tbi.
Old Nov 13, 2003 | 12:46 AM
25THRSS's Avatar
I have an auto. TBI is speed density too and I don't think there is any way you can change it in the chip regardless of tbi or tpi. Anyways, so you guys recommend I change it with speedo gears over the dakota digital box or what?
Old Nov 13, 2003 | 02:33 AM
Kandied91z's Avatar
i did mine with it....so if it is in fact sd you shouldn't have a problem.
good luck.
Jorlain
Aug 24, 2022 05:11 PM
jklein337
Sep 19, 2018 06:23 PM
jharrison5
Aug 19, 2015 05:53 PM
Street Lethal
Aug 14, 2015 08:25 PM
mizz0313
Aug 12, 2015 06:45 AM
