AC dummy pulley
Old Apr 24, 2003 | 12:24 AM
jayhah2's Avatar
AC dummy pulley
Does anyone know where i can find a dummy pulley for my AC compressor. I have looked around on the net, but I havnt had any luck. To be quite honest I dont even know the technical name for it. Any help on this would be great.
Thanks,
J
Old Apr 24, 2003 | 12:36 PM
MdFormula350's Avatar
a/c delete pulley.
http://www.gmpartsdirect.com/
10055890
Old Apr 24, 2003 | 01:51 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Axle/Gears: 10 bolt 3.23
I would recommend you just get it from gmpartsdirect.com also. I've seen one of these go on ebay for $55 before shipping! It's only $38 dollars through gmpartsdirect and I price quoted it $45 shipped to me UPS ground. Just make sure you get that part number.
If you decide to buy of someone make sure you get a pulley like that. I've seen people from various places on the net try to sale the 4th gen style saying it was for a 3rd gen. The 4th gen is very thin. The 3rd gen has all that spacing on the bracket to mount in the OEM AC bracket.
Old Apr 24, 2003 | 02:54 PM
jayhah2's Avatar
Originally posted by MdFormula350
a/c delete pulley.
10055890
Thanks man, I appreciate it:rockon:
Old Apr 26, 2003 | 06:21 PM
89IRO's Avatar
What is the point of that pulley? My A/C doesn't work so would I use this or what? I'm confused. -89IRO
Old Apr 26, 2003 | 09:41 PM
john5.7 87Iroc's Avatar
Car: An '87 Italian Retard Out Cruisin'
Engine: LS1 install in progress
Transmission: 4L60e
Axle/Gears: 9 bolt
Its so you can remove your compressor and use the same size belt. like if you wanted to remove weight or free up space in the engine bay.
Old Apr 28, 2003 | 08:45 AM
89IRO's Avatar
I looked on that website but couldn't find it. Where do I go? -89IRO
Old Apr 28, 2003 | 09:49 AM
go to the site and then put the parts number 10055890 into the parts number space in the left top corner.
Old May 1, 2003 | 08:08 AM
formul8!!'s Avatar
Car: 2004 GTO
This is what it looks like installed:
Old May 7, 2003 | 01:20 PM
bdiroc's Avatar
Car: 1989 camaro
Engine: 355 tpi
Transmission: 700r
Axle/Gears: 3.50
anybody know how much weight it saved .does 20 pounds sound about right?
Old May 7, 2003 | 02:09 PM
89IRO's Avatar
Wow, that does clean up engine bay. I just need to figure out how to put all that emission stuff and heater hose closer to the manifold (soon to be header) so I can show off my new valve cover on the pass. side. You guys know what I'm talking about? It is all the crap on top of the valve cover. You can see it on the above pic. -89IRO
Old May 7, 2003 | 02:40 PM
Engine: 383 SBC
I've heard it saves 30-45 lbs... you figure in all the tubing, compressor, condensor (mounted in front of radiator), smaller heater box, and what ever else I forgot.
For the emission stuff. If you have the CATS removed or gutted you can do away with the AIR pump and tubing. Go to your local hardware store and get some pipe cap ends to do on the AIR tubing coming off the headers or manifolds. Once you cap that off you can do away with the hose running from each and going to the black box shape. After that's done you can remove the AIR pump totally (located under the AC). You will have to reroute (getting smaller belt) or get a dummy pulley for it. You then can cap off or remove the tubing coming off the CATS up to the passenger side under the hood. It'll clean up a bunch of stuff.
Old May 7, 2003 | 06:16 PM
firedawg225's Avatar
Car: 1992 Camaro RS
Engine: 383 w/Holley Stealth Ram
Transmission: Pro-built 700R4
does anyone know if you can still buy the AC delete box that goes on the firewall?? if so do you have a part # and were to buy it?? thanks
Nick
Old May 7, 2003 | 10:25 PM
Badazz86z28's Avatar
Car: 88/Form 86/Z28 87 Trans
Engine: 305 TBI 305 Carb 350 TPI
Transmission: 700r4 x3
Some guy on here sells one don't rember who though
Abubaca's Avatar
I think it's listed as a water pump pulley.
But a part number is a part number.
Do the search, like MDformula recommended.
Old May 7, 2003 | 10:26 PM
Just to remind the folks that is only nessiacary for Serpentine belts
Old May 8, 2003 | 06:22 AM
Car: 1992 Camaro RS
Not the pulley the box that goes on the firewall. when you remove the A/C condensor. They have a box that replaces or came with cars w/o A/C no holes. thnks
Nick
Old May 8, 2003 | 07:14 AM
Yeah dude some guy on here sells one it gos across the holes i bought one
Old May 8, 2003 | 04:39 PM
Car: 1992 Camaro RS
thanks Bad i was just commenting to the persone that told me it a pulley. sorry for the confusion and thanks for the info.
Nick
Old May 8, 2003 | 07:14 PM
No problemo I just wish i could rember who the hell sold it to me hehe
Old May 8, 2003 | 08:01 PM
Engine: 383 SBC
The AC Delete (no Air Conditioning) heater box has been discontinued from GM. But you can still get one from Dave his address is Dave's Web Page
I just recently got one from him. I highly recommend him. It came painted black in perfect condition. It had blower motor (which he bench tests so you know it works). I think it was about 80+ bucks.
As for the AC delete bracket and pulley it is listed in the water pump pulley catagory and it has description saying its a pulley as is... but that is the bracket and pulley as seen in the picture... When you get prices this much cheaper than the dealer and they have so many items to list I guess they can't spend too long on each item description.
Old May 8, 2003 | 08:04 PM
Yep thats him where i got it from
Old May 10, 2003 | 11:49 PM
95Z34's Avatar
i am with stupid.
thanks
Old May 10, 2003 | 11:53 PM
@ZZKKER's Avatar
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
wow, that is nice, anywho, does anyone know the smog pump delete pully? my ac still works some what, and a will recharge it, so it stays, but removing all the air crap would be nice.
thanks
anthony
Old May 11, 2003 | 07:39 AM
Car: 1992 Camaro RS
this is off the topic but you don't need a delete pull for that. jus remove it and all the crappy tubes and crap. and then get a shorter belt. also look in the tech page because you have to reroot the belt but it's not hard. good luck
Nick
Old May 11, 2003 | 05:53 PM
@ZZKKER's Avatar
wow, fu(k you very much gay bill. anywho back to the topic, does anyone know the part number for a belt that will work with the smog pump removed?
thanks
anthony
Old May 11, 2003 | 06:10 PM
Car: 1992 Camaro RS
thanks
anthony
go here this will help
https://www.thirdgen.org/newdesign/t...rpentine.shtml
Old May 18, 2003 | 11:51 AM
Engine: 383 SBC
I used a 967k6 for mine. It was a 350 with all stock pullies (total serpentine) with no smog. When I went down to the 3 piece march underdrive pullies I used a 935k6 (it's 12 bucks cheaper than the 940k6). I guess 1/2 inch is worth 12 bucks to autozone Anyways both belts fit fine and I've no problems so far with them. They do run a little close to the waterpump pulley but still enough clearance.
Old May 18, 2003 | 09:40 PM
@ZZKKER's Avatar
thanks for the help.
anthony
Old May 22, 2003 | 10:13 AM
ILikeFtLbs's Avatar
Car: Whatever I can get to start.
Engine: broke 305 H.O. (now a N.O.)
I think there's some confusion here. Some of you seem to be talk ing about the A.I.R. Injection pump while others are talking about the air compressor. The first is for directing exhaust flow for emissions and to make the car run better in cold weather while the EGR valve is activated. The other is for your air conditioning. Removing the A.I.R. Injection pump helps performance a little because it takes away some of the engine's restrictions. The AC won't do anything aside from add a little weight as long as it's off.
bigjay89gta
Oct 15, 2015 08:04 AM
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
anesthes
Sep 30, 2015 07:48 AM
JSDaddy189
Sep 26, 2015 03:50 PM
