altenator wont charge
Old Jun 5, 2002 | 07:19 PM
Dex's Avatar
Dex
I just got done putting my fan on a switch now the altenator isnt chargeing I did away with the realy to do I need it for the altenator?? altenator was test and said to be good so where do the wires that plug into the altenator go
black=starter soenoid?
white=volt gauge?
red=power?
Old Jun 6, 2002 | 02:12 PM
Dex's Avatar
Dex
anybody
Old Jun 7, 2002 | 11:47 AM
Vader's Avatar
Dex,
The fan relay shouldn't have a direct impact on the alternator charging. It's more likely you disturbed some other wiring in the process of installing the control or removing the relay.
That large (usually red, sometimes black) wire from the alternator output stud is connected to the battery positive lead via a fusible link.
IIRC, the two wire connector to the regulator has a red wire connected at the starter (or other positive power node) and another wire to and ignition circuit (switched by ignition).
Old Jun 7, 2002 | 02:21 PM
Dex's Avatar
Dex
You would think that the fan would have nothing to do with the altenator but guess what with a blown fan fuse altenator will NOT charge just doesnt seem right:lala:
Falcon50
Aug 22, 2020 03:26 PM
apie2546
Oct 16, 2016 02:24 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
RS Reaper
Sep 27, 2015 07:04 PM
