Battery Wont Stay Charged !HELP!
Old Sep 24, 2003 | 08:33 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Axle/Gears: 4.10
I have a 91' GTA LB9 w/700R4. All of a sudden after washing the car (not under hood) my car started reading @11.0 volts. Well i had my doubts that altenator was bad being new so i road around for about a hour (at night w/headlights on) and the volts slowly went down to about 10.0volts. At that time i was at home and went to bed. The next morning on the way to work the battery finally got so low that the car started missing and wouldnt hardly run. I pulled over got a jump and went on. I took the alternator and battery and got them tested. The battery was bad and the alternator was good. Bought a new battery and installed it with new side post. Just went driving and eventually the battery started going dead. It like something is draining my battery faster than my alternator can charge it. Any suggestions?Ask for more info.
Old Sep 29, 2003 | 10:16 PM
@ZZKKER's Avatar
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
check to make sure you are geting the turn on signal to the alt. it should be the small red wire on the connector.
good luck
let us know.
anthony
Old Sep 30, 2003 | 11:03 AM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Axle/Gears: 4.10
i found the problem. Someone had some type of remote wire running to the fuse box and i kicked i out. thanks
gta892000
Aug 11, 2019 11:16 AM
z28joe2
Sep 28, 2015 05:54 PM
Johnoooooo
Sep 22, 2015 08:55 AM
J.C. Denton
Sep 21, 2015 04:23 PM
sahlomonic
Sep 20, 2015 07:15 PM
