easy way to check if alt is failing?
Old Mar 11, 2004 | 08:55 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
well guys i got the feeling the my alternator is screwed, when i'm driving my lights and my dash will dim for a bit then get bright again.
is there an easy way to check?
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
Transmission: 700-R4
take your car to autozone, they'll check it for free.
Shane
Old Mar 11, 2004 | 09:46 PM
Wishmaster's87IROC's Avatar
Engine: 385 HSR.....LS1
They probably dont have that in Canada...I guess...
Heres the trouble shooter sheet I got with mine.
Old Mar 11, 2004 | 09:47 PM
Old Mar 11, 2004 | 09:55 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
hmm thanks guys, i've also been getting some sqeaking noises that it hought was a belt.
i guess i'll cehck it tommorow morning
Old Mar 11, 2004 | 10:09 PM
Skatepunk60's Avatar
Car: Hardtop 84' z/95' Cheyenne
Engine: 305 H.O./4.3L
Transmission: 5-speed manual/Auto
When i had my v6 i had a squeaking i thought was a belt but i replced the belts and it was still there. Turned out to be the altenator bearing
Old Mar 11, 2004 | 10:11 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
EDIT: Never mind.
Old Mar 11, 2004 | 10:42 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
well the alternator in this thing sure isn't new, i know its from a junkyard. might just be worth it to get a new one
Papaginos
Sep 27, 2015 03:29 PM
JHX
Aug 29, 2015 02:30 PM
Bryan F
Aug 27, 2015 07:28 AM
BurlyChev
Aug 16, 2015 09:08 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
