Mechanical Oil pressure guage port, blocked?
Old Sep 4, 2005 | 05:00 PM
ChevyRacer's Avatar
Car: 86 Camaro Iroc-Z
Engine: 355 TPI
Ok, heres the dealeo, i had my mechanical guage hooked up to where the stock electrical guage plugs into. It worked great. But only becuase where the plug that exist above the oil filter normally is. Mine was plugged with something not removable. I drilled it and tried to use a rever direction bit to remove it and it wouldn't budge. so i had to fill it with JD weld.
How can i plug my stock guage and my mechanical guage up all at once? Are there t-fittings i can use to hook them all up?
Is there a way to drill and tap that plug so it can be used effectively? At this point i have no clue what todo.
Where is another pressure point? Its an older block, early 70's. where would a port be?
Old Sep 4, 2005 | 05:12 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
behind the intake manifold, on the block deck/lid...pass side.
Also, may be one on the pass side front above the water pump on the block (the L48? in my folks Vette has a mechanical gauge there)
Old Sep 4, 2005 | 05:15 PM
ChevyRacer's Avatar
Engine: 355 TPI
any photo's/digrams to show me exactly where you are talking about?
Maybe just use a photo you already have and make a dot in paint or something. I have an idea where you are refereing to, but no real area to check, and it wont be worth just removing plugs to find a pressure port.
Old Sep 4, 2005 | 05:33 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
No, sorry no pics, both are 1/8th NPT though.
Old Sep 4, 2005 | 11:18 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Axle/Gears: 3.54 Dana 44
You can use a street T or something similar to put them both in the same port.
Old Sep 5, 2005 | 12:44 AM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
Re: Mechanical Oil pressure guage port, blocked?
Originally posted by ChevyRacer
...How can i plug my stock guage and my mechanical guage up all at once? Are there t-fittings i can use to hook them all up?
...Its an older block, early 70's. where would a port be?
The Motown block in my '88 has a port just the right of the #7 cylinder on the section of the block that bolts to the tranny (this is in addition to the one next to the Dizzy.) I don't know if stock blocks have it.
I only use the side port, to feed the gauge sender, pressure switch, and mechanical guage with a braided hydraulic hose to an aluminum manifold block.
89GTAOz
May 16, 2020 09:31 AM
355sbcTPI
Aug 19, 2015 04:38 PM
R3500
Aug 17, 2015 12:16 PM
bamaboy0323
Aug 15, 2015 07:20 AM
