anybody rebiuld a TPI throt/body?
Old Jan 15, 2006 | 12:49 PM
b_the_j's Avatar
Car: 92 RS
My throttle blade are gettin a wee bit wobbly. I would like to correct this before i start making custom proms, however I cannot find any information (or parts) on this subject. I just need a pont in the right direction. btw it is an 86 t/b also i remember there being diferences about MAF and S/D t/bs, any one know what these are? I am running this one as S/D.
Attached Thumbnails anybody rebiuld a TPI throt/body?-picture-0332.jpg
Old Jan 15, 2006 | 01:09 PM
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
very nice engine! You wouldn't happen to know the paint color or paint code of that red would you.
Old Jan 15, 2006 | 01:53 PM
b_the_j's Avatar
Car: 92 RS
its duplicolor metalcast anodized red
Old Jan 15, 2006 | 02:00 PM
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
thanks!
Old Jan 15, 2006 | 11:05 PM
b_the_j's Avatar
Car: 92 RS
np
Old Jan 15, 2006 | 11:33 PM
Camaro90's Avatar
I know that when it is professionialy done they remove the shaft and drill holes out so that bushings can be installed. I've never had one of the TPI throttle bodys apart but I know that alot of carburators had replaceable bushings once you removed the throttle shaft.
Old Jan 16, 2006 | 08:54 AM
b_the_j's Avatar
Car: 92 RS
thanks camaro 90, thats what i figured, just wondering if anyone had tried it before, i dont wanna accidently open up an air passage or somehing. I imagine everyone just buys a bigger throttle body.
Old Jan 18, 2006 | 07:48 PM
Rob Wade's Avatar
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
ebay--air intake and fuel delivery--tpi The ad I usually see is about $149.00
Old Jan 19, 2006 | 12:44 PM
b_the_j's Avatar
Car: 92 RS
THanks Rob but i am not looking for a rebiult t/b im looking for the bearings so i can seal my throttle shaft
Old Jan 19, 2006 | 03:14 PM
shaggy56's Avatar
Car: 71 Nova
Axle/Gears: 8.2 posi 3.08
dissasembling TB
I found these instructions when i did a search. These are for boring your stock throttle body larger but same should apply to you.
https://www.thirdgen.org/techbb2/sho...tle+body+lever
You know I wonder if you can buy the replacemnt parts for the throttle bodies because I havent seen anywhere that sells them.
Old Jan 19, 2006 | 04:16 PM
89IrocZ350TPI's Avatar
Car: ws6
Engine: ls1
Transmission: m6
That is a cool looking engine.
Old Jan 19, 2006 | 04:54 PM
Rob Wade's Avatar
Thats what this guys has done on ebay. If you read the auction the shaft bushings are replaced with sealed bearings which is the standard repair. Click on his ad and click the "ask a question" link and ask exactly what he does. I don't think you have to get it bored, he should just be able to fix the throttle shaft play, I would think.
Old Jan 20, 2006 | 01:03 PM
b_the_j's Avatar
Car: 92 RS
Thanks guys I preciate it I let everyone know if if find some bearings or what not.
Old Jan 20, 2006 | 05:18 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Throttle bodies are certainly cheap enough, I see them sell for $20-$40 all day. Maybe just get a used one that you can check for wobble first?
stalkier
Dec 6, 2015 11:25 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
Keith5
Aug 27, 2015 04:37 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
