South West Region South West regional discussion board.
Attack of the Killer Steel Belted Radial
Old Aug 25, 2004 | 02:44 PM
azcamaro's Avatar
Car: 1987 IROC-Z / 1992 Corvette
Engine: 305 TPI / LT1
On my way to get the tire replaced, I had a blow out on the freeway. I was maybe 2-3 miles from the tire shop. The steel belts separated and as you can see, totally messed up my car. Ripped the ground effect off & beat in a massive dent.
So now I need to replace the ground effect. Does anyone in Phx have one? Passenger side ¼ panel, behind the rear wheel piece. If you do you can email or pm me with price.
Attached Thumbnails Attack of the Killer Steel Belted Radial-imag0005_sm.jpg
Old Aug 25, 2004 | 02:45 PM
azcamaro's Avatar
and...
Attached Thumbnails Attack of the Killer Steel Belted Radial-imag0019_sm.jpg
Old Aug 25, 2004 | 03:24 PM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
HOLY CRAP!!!!!!!!!!!!!!!!!!!!
Old Aug 25, 2004 | 05:17 PM
85VortecTA's Avatar
Car: Trans Am
Engine: chevy 350
damn.
Old Aug 25, 2004 | 06:19 PM
screaminformula's Avatar
Car: 1987 F150...PAAARTY FOUL!
Engine: 300 I6 stump pullin sumbiscuit
Transmission: 4 speed grind box
Axle/Gears: 3.55 unlimited slip differential
that sucks hardcore donkey d*ck. im sorry to hear about that. hopefully you can get it repaired fairly cheaply. i would look in a junkyard to find the gfx piece and possibly experiment a little bit with a rattle can to have it lookin good again on the cheap...
Josh
Old Aug 25, 2004 | 08:46 PM
azvolfan's Avatar
Car: currently thirdgenless!!!
What kind of tire were they?
Old Aug 25, 2004 | 11:51 PM
90RS305's Avatar
Car: 96 Silverado/99 Suburban
Transmission: 4L80/4L60
Axle/Gears: Chunky/Clunky
Had that same damn thing happen to me and my buddies in an 84 Bronco II.........
Old Aug 26, 2004 | 01:22 AM
lucky you didnt flip, it being a Bronco II
Josh
Old Aug 26, 2004 | 01:49 AM
90RS305's Avatar
Josh
Yeah, no kidding! My buddy that was driving litterally thought we were being shot from the sound it made. I was sitting over the tire that was doing it so I knew what was happening. I kept going "were gonna die...were gonna die....were gonna die......"
Old Aug 26, 2004 | 03:22 AM
well, you guys were lucky...that has always been a fear of mine...luckily no friends of mine drive Bronco Deuces...
Josh
Old Aug 26, 2004 | 11:00 AM
azcamaro's Avatar
Futura
Old Aug 26, 2004 | 12:19 PM
90_WS6_Formula's Avatar
Car: 91 Z28
they have tons of those at ecology
Old Aug 27, 2004 | 11:42 AM
azcamaro's Avatar
I was thinking of going there today after work to get the ground effect.
Old Sep 27, 2004 | 06:14 PM
Car: 91 Z28
How is this going, Lisa?
Old Sep 29, 2004 | 08:18 AM
azcamaro's Avatar
Almost done. I thought I was ready to paint last night...but with the rain & humidity I didn’t think it would be a good idea.
My brother backed into a pole & put a crease in the same 1/4 panel, had it popped back out, but you could still see it if you looked close enough. So I've been working on that too.
We used a wench + a dent puller to pull the wheel well back out. I have (oops I mean HAD) a friend who is a body tech, but he turned into a major flake. So I've done the whole thing myself, with help from my brother. I figure if I don't like the end result, I can always give into my better judgment & ask my Ex to fix it. But only as a last resort. I had been using Bondo spot putty, but I read in a thread in the body section not to use it because it will bleed through to the paint. So I started using Bondo "Plastic Metal", which I'd been using to patch a crack in my ground effects. I defiantly like it better.
I've taken pic's of the different stages of repair. I'll post them when I finish. I'll want opinions if it's a descent enough job or a 'do over'.
Old Sep 29, 2004 | 04:02 PM
90RS305's Avatar
We'll be ready. If you haven't figured it out yet, this is DEFINETLY the right forum for an honest opinion Good luck on getting it done!
Old Oct 11, 2004 | 12:58 PM
azcamaro's Avatar
I finally got done on Fri.
I'll post pic's when I get home from wk later today!!!!
No More Rolling Dumpster!!!!
Old Oct 12, 2004 | 08:20 AM
azcamaro's Avatar
I'm happy with the way it came out. Still need to buff out the paint, so it blends in.
What do you think?
Remember I will be getting a good paint job around XMass (I hope). Which my car needed before the attack.
Old Oct 12, 2004 | 08:22 AM
azcamaro's Avatar
and.......
Old Oct 12, 2004 | 01:41 PM
90RS305's Avatar
:rockon:
Old Oct 12, 2004 | 01:48 PM
85VortecTA's Avatar
Car: Trans Am
Engine: chevy 350
looks good mang.
Old Oct 14, 2004 | 07:26 PM
camaro-mayhem's Avatar
Car: Camaro
Engine: 355c.i.
Transmission: th350
did you take out the center section of the spoiler or just put the other one right over it?
Old Oct 16, 2004 | 07:56 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Josh
A friend said they lowered the roll centre on the Explorer IRS significantly over the olde live axle.
Old Oct 20, 2004 | 09:23 AM
azcamaro's Avatar
I put it right over it. Here's a couple of pic's, let me know if you want a pic with better detail & I'll take one.
Old Oct 20, 2004 | 09:27 AM
azcamaro's Avatar
and...
Attached Thumbnails Attack of the Killer Steel Belted Radial-spoiler2_sm2.jpg
Old Oct 20, 2004 | 09:28 AM
azcamaro's Avatar
last one.....
Attached Thumbnails Attack of the Killer Steel Belted Radial-spoiler3_sm2.jpg
3rdgenparts
May 21, 2016 11:50 PM
sparks454
Interior Parts Wanted
Oct 18, 2015 03:18 PM
SRKLEGIN
Oct 12, 2015 07:28 AM
SRKLEGIN
Sep 30, 2015 07:19 PM
kitt23
Sep 26, 2015 07:48 PM
