Tranny swap help needed - Auto to T-5
Old Jul 11, 2001 | 08:54 AM
89Iroc-ZL98's Avatar
Car: 1989 Chevrolet Camaro IROC-Z
Engine: 5.7L TPI
Transmission: WC T-5
I am getting ready to install the T-5 and have a crossmember question. I have two crossmembers, one out of the donor car and the original. Problem is I don't remember which one was which. One has a dip in the center to lower the mount and one is straight across. Which one should I be using on the 5 speed?? I think the straight one was from my auto but am not sure. Any help is appreciated.
Old Jul 11, 2001 | 01:59 PM
irocnroll89's Avatar
From: previously OKINAWA JAPAN,georgia, now new england
Car: 1989 IROC--1989 T/A
Engine: 5.7 TPI in both
Transmission: W/C T-5 in both
Axle/Gears: B/W 3.27 in both
hmmmm. i just did that swap 1 week ago, and that i know of they are the same crossmember. I have both the one from the donor car an '88 camaro, and mine from my 'ROC. I don't even know which one i used SHAGGY
'89 SHAGGY IROC
L98, W/C T5, all free stuff,T.E.S.,HOOKER CAT BACK,KYB,ACCEL8.8,JET fan sw. etc. 14.8@ 95.7MPH w/ auto, can't wait for the first T5 run.
so much to do , so little money
[This message has been edited by irocnroll89 (edited July 11, 2001).]
Old Jul 12, 2001 | 04:38 AM
BOWTIROC's Avatar
From: Coulterville, IL...Currently on Beale AFB, CA
I just used the one from the auto, I have had no problems.
Black 89 IROC...355, Solid Crower Cam, TFS heads.
12.0 @ 120.3mph with a 1.9 60ft...all motor
Old Jul 12, 2001 | 08:41 AM
MikeS's Avatar
The one in my 84 T-5 car is pretty straight. It is one straight bar all the way across with another shorter one bolted to the top of it on some rubber bushings or something
Old Jul 13, 2001 | 03:31 PM
Engine: 5.7L TPI
Thanks for the info. I'll use the straight one.
IROCZ1989
Jan 24, 2016 03:55 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
