Foglights
Old Feb 17, 2004 | 11:01 AM
1986sc's Avatar
Car: 92 Z28 92 RS Vert
Engine: 350 TPI 305 TBI
Transmission: 700R4 Auto (2x)
Foglights
finally found a set of fogs :lala: they are not GM or OEM but they sure do look like it! i fabricated my own brackets just like the factory ones. If anyone wants to put foglights on CHEAP..this is the way to go.. go to autozone....the brand name are BLAZER.
Gas for the trip to autozone....... $4
Blazer foglights to pretty up your baby....$17
Finally being able to see at night ....priceless
.....for everything else theres Autozone
Old Feb 17, 2004 | 11:17 AM
1986sc's Avatar
# 2
Old Feb 17, 2004 | 11:22 AM
Demon355's Avatar
Nice dude!
Old Feb 17, 2004 | 11:25 AM
FyreLance's Avatar
Car: 00 TA, 91 Formula, 89 RS
Doesn't look half bad... first time in a long time that I've seen aftermarket fog lights on a car that didn't blatantly obviously look like they were aftermarket fog lights.
Old Feb 17, 2004 | 12:29 PM
86WS6_T/A's Avatar
Car: 2003 Mach 1
Those blazer lights are a direct replacement for the 85-90 Trans Am fog lights. Even if you want to keep the stock brackets and such, you can use the reflective buckets and the lense from them and it will all bolt back together.
Old Feb 17, 2004 | 12:31 PM
87rediroc's Avatar
Car: 87 Iroc (summer only)
Engine: 5.0 TPI
Transmission: 5 speed
Looks good!
Old Feb 17, 2004 | 12:45 PM
NEEDforSPEED's Avatar
ya looks good
Old Feb 17, 2004 | 02:43 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
Yea those are nice, thats the same ones i put on mine, there really bright, i get people bright lighting me at night, i guess i should probably adjust them. They look good
Old Feb 17, 2004 | 02:53 PM
bes217's Avatar
How did you wire them up? They just come on with your headlights or is there a seperate switch. I don't have fogs on my car now but those look awesome and I really want them. Details please!!!
Old Feb 17, 2004 | 08:38 PM
1986sc's Avatar
bes 217..... yeah, the set came with a switch. the wiring was simple. into the back of the switch went three prongs. one for the ground, one for the lights, and one for the fuse. just plugged right in. But the only fabrication you need to do is strip the fuse ending and put a teminal on the end that will fit right into your fuse panel. there are two spots in the fuse panel labeled "fog lights" i only needed to use one. any more questions ..feel free. sorry if i confused you . later RYAN
Old Feb 17, 2004 | 08:41 PM
bes217's Avatar
Ok thanks a lot, I have bookmarked this thread, so when I get around to putting on the lights I can check back.
Old Feb 17, 2004 | 08:52 PM
Quick6's Avatar
Car: 1991 Camaro Z28
Engine: L98 5.7 V8 TPI
Those are the same fogs I had on my 91.
Old Feb 17, 2004 | 09:52 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
i found some great foglights at autozone for 20 bucks too and they look great!!! not the round crappy amber beams but some good ole foglights that look pretty factory. BTW those look sweet!
Old Feb 17, 2004 | 11:20 PM
1986sc's Avatar
CAMAROS RUS , what brand did u pick up ?
Old Feb 18, 2004 | 08:40 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
you konw i couldnt tell ya.......iremember it was in a grey box, Blazer sounds familiar but ii dont have the ones first posted here. mine are a little more narrow than the stockers but i think they look great
Old Feb 18, 2004 | 10:01 AM
CamaroRS385hp's Avatar
Car: 1987 Iroc-Z28
Transmission: auto
where could i buy replacement brackets? the ONLY thing on my car that i'm not happy with is the brackets. somehow with the previous owner they got bent up and rusted a little
Old Feb 18, 2004 | 10:22 AM
1986sc's Avatar
heres a link for the fog light bracket..... http://www.hawksthirdgenparts.com/in...l?v=1&pid=8557
but rather than spending 75 bux after shipping, id just make em
also i found this on ebay.. http://cgi.ebay.com/ebaymotors/ws/eB...category=33709
Old Feb 18, 2004 | 05:00 PM
Car: 1987 Iroc-Z28
Transmission: auto
lol yeah i think $5 plus shipping sounds a little better than $56 plus tax and shipping...thanks for the link
Old Feb 19, 2004 | 09:56 AM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
they sell the blazer fog lights at walmart to. you can get the clear/yellowish ones like the ones pictured above or you can get some prizm color thinger like when you look at gas or oil with the many colors.
Old Feb 20, 2004 | 09:59 AM
kid camaro's Avatar
Car: 91 z28
Engine: 305 tpi
when i wired my fog lights up to my 84 that didnt have it set up for it. im not sure what the part is called but what it does is let you splice into a wire without havin to cut it. i used one of those and spliced it into my side marker lights. so when ever i pulled my park lights on they woukd turn on. it took like 15 mins to hook everything up. ill see if i can find a pic of the connector.
Old Feb 20, 2004 | 02:02 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
looks good.
I finally got a set of factory ones for free when I installed a set of aftermarket ones on a friends car.
I took off my ugly looking aftermarket ones and put the factory ones in. Makes it look a whole lot nicer.
Old Feb 20, 2004 | 03:43 PM
TekViper's Avatar
Car: 1990 Pontiac Firebird
Engine: 3.1L v6
Transmission: Automatic
yep i have the blazers on my firebird. I just swapped in the reflector, bulb, and glass from the new blazer fogs into the metal housing of the stock foglights. That way it bolts right up to the bracket like normal. looks exactly like the stock ones except maybe they are a little brighter. They overpower my headlights i think lol. here is a picture
Old Feb 23, 2004 | 02:57 AM
sheltonw3's Avatar
Car: 91' TRANS AM Modified
Engine: Classified
Transmission: Auto with Overdrive
Foglights!.....gotta love'em
I use pilot brand on my 91' T/A
Old Feb 23, 2004 | 05:46 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
yah i have the pilot ones on my car and my friend has the same set on his IROC-Z.....i think they are pretty good for the money...
Old Feb 23, 2004 | 06:24 PM
2 dope's Avatar
Car: 1985 Camaro Z 28
Engine: 305 LG4
any pics of fabbed brackets?
Old Feb 23, 2004 | 09:42 PM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
I have blazers.
Old Feb 23, 2004 | 09:50 PM
1bdbrd's Avatar
Car: 1991 Trans Am
what kinds can i use for a 91? my drivers side has a rusted casing on it so it shorted out. ive searched quite a bit and have only found the 85-90 style. which ones would work and look good on a 91?
Old Mar 1, 2008 | 08:06 PM
allgood's Avatar
Car: 92 WS6 Trans am convertible
Engine: ls 6.2
Transmission: 4l80
Axle/Gears: 2.73's
Re: Foglights
any one with a 91 or 92 trans am have clear fog or parking light lens?
If so where to get them.
Old Mar 2, 2008 | 01:15 AM
iggy89's Avatar
Car: 86 Camaro
Engine: 79 350 carbed
Transmission: TH-350
Axle/Gears: 3.73 posi
Re: Foglights
Interesting thread. Do these happen to plug right into the camaro foglight wireing? My camaro has the wiring and brackets but no foglights. some reason the last guy did keep them and replaced them with oval ones.
Yellow Camaro
Dec 1, 2001 04:01 PM
Monkie
Oct 19, 2001 11:30 AM
TZFBird
Sep 5, 2001 06:09 PM
Doogie92Z28
Jun 26, 2001 09:14 PM
George Khawahie
Jul 28, 2000 09:52 AM
