What are these wires for? And this hole?
Old Mar 15, 2005 | 01:07 PM
luvmy64's Avatar
Hey guys,
The car was this way when i bought it, and i dont know if someone has clipped a relay off or what. Can someone tell me whats missing?
Also, what went in that big hole? (second picture)
Old Mar 15, 2005 | 01:13 PM
luvmy64's Avatar
let em try this one mo' time.....
Attached Thumbnails What are these wires for?  And this hole?-c-documents-settings-chance110
Old Mar 15, 2005 | 01:16 PM
luvmy64's Avatar
And now the hole i spoke of...by the way, this is on a 89 RS.
Old Mar 15, 2005 | 02:21 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
I'll take a stab at this.......
The big hole is where the blower resistor fits into.
The cut wires probably had a connector that pluged into the blower resistor.
I take it your heater/AC fan doesn't work?
Old Mar 15, 2005 | 02:33 PM
luvmy64's Avatar
Well, if you can see the fan on the left side of the pic, youll notice that it is unbolted for some reason. What does this resistor look like? Someone care to go out and snap a pic of theirs for me?
Old Mar 15, 2005 | 02:39 PM
luvmy64's Avatar
Is this it? If so, which wire goes where?[IMG][/IMG]
Old Mar 16, 2005 | 02:30 PM
luvmy64's Avatar
bump
Old Mar 16, 2005 | 04:32 PM
WILL85IROC's Avatar
Car: 85 IROC-Z Z-28, BLUE & SILVER
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
looks like someone disconnected your heating and a/c .... looks like your also missing that silver canister thingy for your a/c
Old Mar 16, 2005 | 05:01 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
that is almost the connector. the one on our cars has 4 prongs. one for the purple wire, and 3 more for those other 3 wires, yellow blue n tan i think
Old Mar 16, 2005 | 10:05 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Here's a photo of what's missing. This is from my '87.
Blower Resistor
Old Mar 17, 2005 | 07:02 AM
luvmy64's Avatar
Paulo,
Couldnt get picture to come up. Please repost!
Also, i have about 4 purple wires disconnected there. Which one?
Old Mar 17, 2005 | 12:07 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
hope this helps, this is how the purple wires run, comes straight from the harness, ran down to the plug,then comes back and goes into the plug for the blower motor.
Attached Thumbnails What are these wires for?  And this hole?-c-_documents-settings_chance110_desktop_wires2.jpg
Old Mar 17, 2005 | 02:13 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Originally posted by luvmy64
Paulo,
Sorry about the pic post. Check your PM's. I can email the photo to you.
Old Mar 17, 2005 | 02:15 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Let's try this:
Attached Thumbnails What are these wires for?  And this hole?-c-documents-settings-oshipa00
Old Mar 17, 2005 | 02:22 PM
luvmy64's Avatar
Paulo,
What color is the wire (or wires)going to the fan motor, and what color(s) are the wires going to the relays behind your fuel pressure gauge? (arrows) Thanks for the pic!
Old Mar 17, 2005 | 02:23 PM
luvmy64's Avatar
Crap...forgot to add the pic before i hit enter!
Old Mar 17, 2005 | 03:06 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
one fan motor wire is purple, the other is black.
Old Mar 17, 2005 | 07:29 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Refer to the photo:
#1 - Purple; comes from the blower resistor connector.
#2 - Black; two ground wires. One comes from the Blower High Speed Relay (#3 in photo). The other black wire goes to the ground distribution loop (G112 or G117 depending upon VIN Code).
#3 - Blower High Speed Relay, 4 wires.
Wire #1 - Red (hot at all times).
Wire #2 - Purple (not used) from blower esistor connector.
Wire #3 - Black (ground, plugs into ground spade at blower motor).
Wire #4 - Orange, from Blower switch.
The descriptions come from the service manual for '87 model year.
Attached Thumbnails What are these wires for?  And this hole?-c-documents-settings-paul
Old Mar 17, 2005 | 07:43 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
I think this is where your wires go. Keep in mind that I'm not able to verify what wires are coming and going to and from where.
Refering to the purple and black wire that's labeled "blower"; the black wire should go to the ground spade on the blower and then to chassis ground (ground distribution G112 or G117).
Old Mar 18, 2005 | 06:50 AM
luvmy64's Avatar
Thanks! Now i can at least have heat again.
Jeremys87
Jul 14, 2022 09:08 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
BurlyChev
Aug 22, 2015 01:52 PM
