Boxed LCA's?
Old Nov 27, 2002 | 08:09 PM
black85camaro's Avatar
Car: 85 Camaro
Engine: 350 Carbed
Transmission: Stock 700r4
Boxed LCA's?
Ok, I know when you box the lower control arms that it helps alittle. I also know that there are a few post here about it. I was wondering that if anyone has seen or wrote about this or hads pics of doing it? Like what size/guage steel to use? Could alumin. be used in its place (I doubt you can because it would be had to weld to steel)! I am about to swap rears out of my 85 Camaro for some 3.42 gears out of a v6 bird. I was wondering how much it would help with launching a car off the line. Also the same Q's about the relocation of the LCA. Can that be a "home made project?" Any other free/cheap ideas for traction let me know please.
-Terry-
BTW: Airshocks with 275/60/15's dont hook worth CRAP!!!!!! :lala:
Old Nov 28, 2002 | 05:34 AM
ede's Avatar
ede
you can make LCAs your self. can't weld aluminum to steeel, it'll never happen. anything or any thickness would work, naturally you'd want something you could weld easy. i used 16ga, little thin but it was heaviest i could shear.
Old Nov 28, 2002 | 10:34 AM
erictheviking's Avatar
Car: '92 RS Camaro
Engine: 406ci D1SC SBC
Transmission: TH400
Axle/Gears: 9" W/Truetrac
Here's one made by my good friend the Toecutter.Luckily the steel strip was pretty much the width with just a bit of grinding to tidy it up.The thickness is about 3mm,which is actually slightly thicker than the original lca.The old bushes were pressed out and new ones pressed in with a homemade press.
Old Nov 28, 2002 | 10:38 AM
Car: '92 RS Camaro
Transmission: TH400
The press.This can be used for many Automotive jobs.
Old Dec 1, 2002 | 11:23 PM
MdFormula350's Avatar
nice looking lca's.. must work alot better than the stock ones.
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Ed1LE
Sep 30, 2018 09:14 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Zell1luk
Sep 29, 2015 10:36 AM
