Camaro Front end on a Firebird?
Old May 12, 2003 | 04:38 PM
Soft Taco2's Avatar
I hate the Firebird front end (too pointy, pop up head lights, etc.) and i would really love a Camaro front end on my Firebird. (Firebird Rear ends look better IMO)
Is it possibly to switch them and not have to worry about the front not lining up with the fenders? If you can do this, what all needs to be changed? and how hard is it?
Old May 12, 2003 | 05:55 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Even though you weren't asking for it, expect responces pretty similar to these.. https://www.thirdgen.org/techbb2/sho...firebird+front
This is another post on the subject... https://www.thirdgen.org/techbb2/sho...firebird+front
Yes it can be done. You'll need the entire camaro front clip along with all the crap that bolts on undeneath (impact bar, light mount panel, absorber, etc...). If you can turn a wrench, you can swap the fronts. Time (skill too maybe ?) is in aligning the panels so evething lines up properly. You will also want the headlight wiring from the camaro.
Old May 12, 2003 | 05:56 PM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
You could but what a pain in the ***. The hood and fenders are contoured differently. Depending on the year of your car you do have a couple options though to make it look better. The 1985-1990 Trans-AMs are no where near as pointy as the other years of the thirdgen body style. So if you have a Firebird you won't have the TA style nose. You can get the ground effects and the rear and front bumper covers and get the boxier style. Which is my favorite IMO.
I don't know whos car this is, so if I offended anyone on this board who owns it I appologize.
The other choice is to sell your car and get a Camaro.
Old May 12, 2003 | 06:42 PM
89FormulaRoth's Avatar
Car: 1989 Firebird Formula 350
Engine: 5.7L TPI
Axle/Gears: Borg Warner 3.27
It'd be Frankenbird!!!!!!!! No offense, I like both cars, but I don't think they belong together as one. It's a crime against nature!
Old May 12, 2003 | 08:14 PM
1986redbird's Avatar
if you want to change noses on your car you will have to change the following:
nose
fenders
hood
impact bar
light mount bar
egg crate
basicly everything from the firewall forward (body wise).
Old May 12, 2003 | 11:03 PM
90TA's Avatar
Since both cars are in the same family, I guess it would still be considered an F-Body. Only the F would then stand for Flipper
Do you think it would be worth the possibility of constantly being pulled over because a cop thinks he sees a Camaro but the plates come up Firebird?
Old May 12, 2003 | 11:35 PM
Soft Taco2's Avatar
Well, its either swapping the whole front end body peices or getting a Ram Air hood. (Kinda makes the front end not look so pointy)
I really love the Camaro front end (the agressive look), but i like the Firebirds rear end alot more. Isnt there like a body kit or something to make it more "Boxy" and have the front end drop down like a Camaros?
BTW, i have an 89 Firebird.
Old May 13, 2003 | 04:06 AM
oldblueZ's Avatar
Car: 85 Z28
Engine: 305 TPI (dead) -> building 355
Transmission: 27 spline 700R4 (another one died) -> T5 goin in next
What I would do is get the front bumper like the one pictured above and the Ram Air I hood, not the II. That would make it look sharp.
-Jesse
Old May 13, 2003 | 07:54 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
There is a Cam-bird about 1/2 mile from where I sit, that exact formation... I saw it driving down the road, thought "oh Camaro" it turned the corner, and drove away "oh firebird."
Just a FYI, the doors, windshield, firewall, inner structure are all IDENTICAL on Firebirds & camaros... THE Wheel wells however are 2" longer on a camaro. The Firebird has almost a perfect arc wheel well. A Camaro is (Eliptically) elongated.
Hope that helps.
John
Old May 13, 2003 | 09:48 AM
87WS6's Avatar
Like I said the 1985-1990 Trans-AMs are not as pointy as a firebird. Get the gfx and the rear and front bumpers your set. Get an RA I hood if you want an even more aggressive edge. It would look good.
Old May 13, 2003 | 11:50 AM
Kaps's Avatar
If you do it right I think it would be nice just need to find a parts car that the panels you need are nice, someone else did something simular a while back, so I searched for it, here ya go:
https://www.thirdgen.org/techbb2/sho...threadid=99554
Old May 13, 2003 | 12:03 PM
formularpm's Avatar
Car: '89 Formula
Axle/Gears: 9 bolt
Please dont do it. Itd look strange. I agree with the others, you should get a Trans Am nose instead of going through all that work.
Old May 13, 2003 | 07:10 PM
WillWood's Avatar
Car: 1966 Volkswagen Beetle
Engine: Flat-4
Transmission: swing axle
I've seen it before and I'll try to get someone to get pics.
Old May 13, 2003 | 10:03 PM
Thundering Z03's Avatar
Car: 92 Camaro Heritage
Yeah, I've thought about that myself. If you did a swap like that, you'd have two different types of wheel arches front/back. Camaros are more prominent in appearance, while Firebirds are more smoothly contoured. I don't really think it would look right at all. To the untrained eye, some may not notice that slight difference. But to a purist, it would stick out like a sore thumb. Just my thoughts and opinions.
Old May 14, 2003 | 07:52 AM
okfoz's Avatar
I have seen it done to cars, where they mix breeds, and I cannot explain it but there is something that does not jive... Its almost irritating to my eyes, because I know that there is something wrong but I can't put my finger on it. (Beyond the differences in the front and back ends of the car.)
ALL of the sheetmetal, save the Doors, is different from A Camaro to a firebird. Even the sail panels are different.
John
Old May 14, 2003 | 08:09 AM
87WS6's Avatar
I would just make it look like a Trans-AM and not a Firebird. If you don't want to do that then sell your car and get a Camaro.
Old May 14, 2003 | 08:30 AM
okfoz's Avatar
I Imagine you could cut the rear tailight/bumper section off of a camaro and install a firebird tailight assembly... I think that would look better (If done well) than to just swap the front clip IMO
John
Old May 14, 2003 | 10:12 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I agree with 87WS6. Mix/matching front clips is ridiculous... looks like you're too stupid to buy the right parts. Why not put Toyota Camry front clips on Chevy Berettas? Or maybe an RX7 front clip onto a Mustang? So what if they don't bolt right up; if you have the tools, you can fabricate anything.
Old Mar 3, 2011 | 12:57 AM
icefreak's Avatar
Car: firebird and camaro
Engine: 2.8 and 5.0
Transmission: 700r4 in both
Axle/Gears: ill let u know when i do the swap
Re: Camaro Front end on a Firebird?
ill let you know how a front clip of a 1982 camaro rs will look on a 1989 firebird when i do my motor swap no one can get my front around here so i got my parts car 4 this and more
Old Mar 3, 2011 | 01:06 AM
Dartht33bagger's Avatar
Car: 1991 Z28
Engine: L31-R 350 w/ EBL P4
Wow you just brought back an 8 year old thread.
Old Mar 3, 2011 | 07:25 AM
okfoz's Avatar
Here in-lies the problem... 8 years more experience.
Problem: Will a front clip of a Firebird fit on a Camaro, or vise-verse?
Answer: YES
Problem: But, why does it look funny?
Answer: 1) The wheel well openings are smaller (More round) on a Firebird, and more elongated on a Camaro, there is a bout 2" difference between them. 2) The shape of the fender flair is different. On the Firebird there is a softer line, that blends into the fender itself, the Camaro has a harder line.
Ultimately it will fit, but it will look odd.
John
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
bellez77
Sep 5, 2015 08:39 PM
