what good does coating aheader do?
Car: 1989 Iroc z hardtop
Engine: peanut LB9
Transmission: slopomatic TH700R4
what does it do and is it really worth the $520 compared to $350. another $170 for the coating.
looking at getting aset of hooker 2055's and a 3" cat mufflex 3" catback
Plenty of info on the board about this:-
Some threads that may help include:-
Is Ceramic Coating Necessary?
https://www.thirdgen.org/techbb2/sho...hreadid=181032
To all of those who were wondering about ceramic coating
https://www.thirdgen.org/techbb2/sho...hlight=coating
Jet Coating
Hope that helps!
Jet Coating
Hope that helps!
Transmission: 4L80E/4L80E
Coated headers will produce better performance than the same non-coated headers. It may not be much, it may not be directly an exhaust function, but it is true.
Having the primary flange openings properly matched so they provide a smooth path from the exhaust port will probably make more of a difference than coating.
Originally posted by wyclefsirocz
i don't car eabout heat why should i??? is it gonna make that big of a differnce in performance
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
When you have uncoated headers you get an incredible amount of heat soak througout your engine bay. If you have an open air element you will suk in a lot of hot air and your car will feel sluggish. Headers do not keep the heat in as well as cast iron exhaust manifolds. You are suseptible to burn through plugs wires, and potentially boil settering and brake fluids, if not tucked out fo the way. Coating keeps a lot of the heat in the header.
Engine: peanut LB9
ok just for the wires i will get em, plus there shinny. lol
i was just curios thanks for the links,
five7kid- i have an 305 TPI and i was thinking about hooker 2055's
well, if you like changing your starter every few months after heat soak kills them one after the other... yeah go uncoated. You can go uncoated if you like to save money, but the coating is a great idea and I sugest everyone gets it.
Engine: peanut LB9
how would not coating a header kill a starter sooner?
i understand what your saying if its a long tube, but i'm going w/ shorties, would getting the y pipe coated too make a differnce?
Car: Camaro
Ive heard that the coating helps the exhaust flow better , cant remember where I read or heard that so if you wanna call
on it go for it but I am sure I read it in a tech article. Oh and the heat is a big power robber just like everyone is saying.
on it go for it but I am sure I read it in a tech article. Oh and the heat is a big power robber just like everyone is saying. Member
Car: 1989 rs camaro, 1990 jeep wrangler, 1995 eagle talon tsi awd
Engine: nothing right now
Transmission: j.w. performance th350 3500 10" stall... soon to be t56
trust me heat kills starters, i went through 4 last year.....
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
To get an answer to why it works, or why its worth it, jsut goto the jet-hot website and have them send you their video and articles from magazines. Its free and the info they send will answer all your questions.
ambainb
Apr 25, 2016 09:21 PM
