code 15 and 23 what is up with my car
Old Aug 4, 2002 | 10:40 AM
camaro89rs355's Avatar
Car: 89 Camaro RS
Engine: 355 TBI
my car is pulling a code 15 and 23 i know what they are but what is causing this. I need some help.
Old Aug 4, 2002 | 07:54 PM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
15 Coolant sensor - low temperature fault
23 MAT sensor Low temperature fault (EFI/TPI/SFI)
Old Aug 4, 2002 | 11:12 PM
Car: 89 Camaro RS
Engine: 355 TBI
The gauge on my car reads at 220 when warm. So why is my car pulling the code 15. and why is it pulling a code23, i know what they are but how do i fix it?
Old Aug 5, 2002 | 06:39 AM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
If I was u, I would replace ur Coolant temperture sensor. That might be the problem. Its reading off because its not working right. They sometimes go bad. Are u running rich or lean? When they do go bad, they usually tell the computer to dump to much fuel or not enough fuel into the car. Run ur car until it is at operating temp. and then pull one of ur plugs and tell us the color. If its white, ur lean, if its dark ur rich. It should be a tan color if its perfect.
Old Aug 5, 2002 | 07:36 AM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
There are 3 differnt coolant temp sensors/senders in your car.
There is one in the drivers side head between cylender #1 and #3. That is for your guage, hence why it is reading correctly.
There is one just to the left of the thermostart. It has a yellow and black wire running to it. This is the one that the ECM reads for it's temps. THis is the one that is screwed up. This is the one that you should replace
Then third one is in th passenger side head between cylender #6 and #8. That is your fan switch. Its what controls the fans(s) from coming on and off.
The IAT sensor is prolly old and corred it. Just replace it with a new sensor or a 4.7k ohm resistor. What that will do is make the car think it has 55* incoming air at all times.
Kat
Old Aug 5, 2002 | 08:49 AM
Car: 89 Camaro RS
Engine: 355 TBI
The spark plug is black so it is rich. Plus my fan never comes on unless i turn my air on,what is up with that? Is it the fan relay. Oh and what about the iat, what will putting a 4.7k ohm resistor do? How will it efect the moter. And what does the 55* mean? sorry about the trouble but im getting pretty mad at my car i paid a lot of money for this moter and all i want to do is beat some munstangs. cause everybody in my town just thinks mustangs are the **** and that they cant be beat. Well im going to so them what a chevy was made to do. and what is that, (BLOWING THIER DOORS OFF) :hail: :hail: :rockon:
Old Aug 5, 2002 | 01:49 PM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
Usually the fan will only kick on when the engine temp reaches 255 degrees. BTW: 55* means 55 degrees. Anyways, I would deffiently replace ur Coolant temperture sensor then if that is the case. If u want to have ur fan running at an early temperture, u can make a fan switch were u can turn it on and off as u please.
https://www.thirdgen.org/newdesign/tech/cool.shtml
there is the tech article on how to do it. Pretty easy, but u know what I do. I just flip my a/c on when I think my car is running to hot. makes a good fan switch.
Old Aug 7, 2002 | 04:00 PM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
Hey man, guess what code I pulled today when i got my car running finally? Well I got my car running, looks like it was my coil...bad news I am getting a code 15 now. 15 Coolant sensor - low temperature fault. LoL. So how much did ur Coolant temperture sensor cost u?
Old Aug 7, 2002 | 04:58 PM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
Nevermind, I just went out and bought one for 8 bucks and I am gonna install it here in a second when my engine cools down. Looks like an easy install.
specialized
Jun 18, 2022 09:26 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
mizz0313
Aug 12, 2015 06:45 AM
apie2546
Aug 10, 2015 05:43 PM
