I've got the tool to make removing those front coil springs a breeze!!
Old Oct 14, 2004 | 04:14 AM
grafx's Avatar
Car: 91 Camaro RS
Transmission: Pro-Built Automatic/Vigilante 2800
Tried shortening a spring compressor the first time I removed my springs and had a hell of a time still. I came up with an idea to remove the spring and A-arm together and was so much easier to do and you won't have to cut up a perfectly good spring compressor. What do you guys think??
Attached Thumbnails I've got the tool to make removing those front coil springs a breeze!!-topspringmnt.jpg
Old Oct 14, 2004 | 04:15 AM
grafx's Avatar
Car: 91 Camaro RS
sorry....here's the money shot!!
Attached Thumbnails I've got the tool to make removing those front coil springs a breeze!!-btmspringmnt.jpg
Old Oct 14, 2004 | 05:41 AM
Spdfrk1990's Avatar
Done that i still just prefer to compress it then let the a-arm down specially if you dont want to take the a-arm off. Alot of aftermarket springs you dont have to compress at all just let the a-arm down and they will fall out.
Old Oct 14, 2004 | 07:57 AM
FastZ28*84's Avatar
Car: 84 Z28
Engine: 72 350 .030 over
Transmission: 89 WC T-5
Thats a pretty cool idea. I may have to try that as my springs need about 1 1/2 coils cut. I have been procrastinating it cause the spring compressor is such a pain. Thanks for sharing.
Old Oct 14, 2004 | 10:40 AM
grafx's Avatar
Car: 91 Camaro RS
right this is specificly for stock springs, once I put in my Sportlines I won't have much use for it.
Old Oct 14, 2004 | 01:43 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
umm, that looks just like the spring compressor i rent from autozone (for free) when i have to pull my springs......
customblackbird
Aug 15, 2021 10:16 PM
TheExaminer
Aug 25, 2015 07:34 PM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
TA8487
Aug 11, 2015 09:02 PM
3rdgenparts
Aug 8, 2015 07:09 PM
