Convertible Sub frame Connectors
Car: 92 RS Convertable
Engine: RAMJET 350
Transmission: G-FORCE T-5
Does any one know where I can get a set of SFC'c that will fit on my '92 rs 305 TBI 5 spd convertible? Every good set I have seen says hard top only or not for convertibles.
weld in ones would be prefered
Also does any one know what exacly is different about the floor pan of a convertible? I know (think) the cars started out as T top models?
Thanks Ryan
Thanks Ryan
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
I have the Alstons. Bolt in type but I welded them on instead. Definitely helps stiffen the chassis. The convertible do have tack welded sub frame connectors from the conversion but they were insufficient. Kind of like the engine.
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
I got mine from a place called Coast High Peformance in Cali.
Just do a search on the internet, you'll find a a place. The alstons also allow the installation of dual cats on a ragtop.
Engine: RAMJET 350
I feel like a moron I have searched with yahoo lycos and ask jeeves for some one who sells alstons SFC
could some one help me
thanks
Ryan
thanks
Ryan
Axle/Gears: 3.45, 3.27, 3.27
Hmm, no onder. Sis you serarch on this site? All the info you need:
https://www.thirdgen.org/techbb2/sho...hreadid=111459
Lon
PS: I've got them on my RS 'vert too.
Lon
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
thanks
Ryan
thanks
Ryan
1991, 2002, 91, 92, body, camaro, connectors, convertable, convertible, firebird, frame, install, subframe, subwoofer, z28
