Window handles
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Window handles
Ok, bought a new window handle for the one I have missing, however it seems im missing that spoke that comes out the door panel that the handle clips on to, anyone know the part # for this item? I have no idea what it is called
Car: 85 Trans Am
Engine: 305 Carb
Not sure exactly what you mean, but it sounds like a part of the window regulator itself. Best bet will probably be a junkyard, or advertise on the classifieds here.
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Whoops.. re-read your post. You're missing the actual piece comming from the door panel (i.e... nothing to attach the new handle to)
Yea, im just missing little stud that hangs on the door handle that the new handle clips to. But don't know the name or part # for the item.
Engine: TPI 305/ v6
If you are missing what I am visioning you missing (pictured below), then you are boned. That's part of the window regulator and it has broken off.
I don't think it's an individual (detachable/replaceable) piece from the regulator that can be gotten unless you got it from a junkyard and welded it back on. I've never encountered the problem so I can't say that for certain. If below isn't what you're talking about... just ignore anything I said above
My digital cameras batteries are just shot, can't take a shot of it, hope that helped, maybe someone else knows?
