Q about crossover for duals
Old Sep 15, 2000 | 03:30 PM
Justy's Avatar
This is just a general inquiry. I've heard that dual exhaust systems have a crossover pipe to "scavenge exhaust". What does this mean and is it necessary? The reason I ask is because a friend of mine has duals on his car but without the crossover. He seems to think it's absence is causing this funny vibrating sound from 1000 - 2000 rpm.
Old Sep 18, 2000 | 08:49 AM
Kenn's Avatar
It equalizes pressure of the pipes and helps in scavenging by giving exhaust pulses an alternate route to exit - thats why the X pipe is better than the H pipe - the exhaust flow can move quicker to the other pipe by not having to make a 90deg turn
you'll get about 10 extra horeses versus not having one
About the vibration - I don't know- When I had single exhaust I use to get a vibration at around 3grand where my torque peaked
Old Sep 20, 2011 | 12:50 AM
camarosindahood's Avatar
From: Wisconsin. Currently Southern Milwaukee Area.
Car: 1991 Z28
Engine: 5.7 TPI
Axle/Gears: 4.11
Re: Q about crossover for duals
why is it that the two pipes need to be connected in some way?
Old Sep 20, 2011 | 08:03 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
are you kidding? the first sentence in the post YOU quoted answers that.....
Old Sep 21, 2011 | 01:08 AM
Car: 1991 Z28
Engine: 5.7 TPI
Axle/Gears: 4.11
Oh, ya, i suppose it does lol
wouldnt that be quite difficult on a thirdgen? I mean, its already hard enuf to get a true dual setup in the first place
Old Sep 21, 2011 | 04:43 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
not really, if you do a dual setup, following the stock routing, with 2 pipes side by side, a X pipe would be simple. However, you can fit a single 4" pipe in there with little headache, so i still fail to see the point of most of the interest in a 100 percent custom PIT-f'ing-A dual setup, when a single 4" fits pretty darn well and will support more power than 95 percent of the people on this board put out. Only real difference is the sound the car makes.
Old Sep 21, 2011 | 04:59 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Axle/Gears: 9-bolt 3.27 & PBR
... Only real difference is the sound the car makes.
And there you have it! Some folks will put a lot of effort (and money) into finding just the right rumble for their toy. It's a big part of the V8 joy. I miss it with the 6.
Old Sep 26, 2011 | 11:41 PM
Car: 1991 Z28
Engine: 5.7 TPI
Axle/Gears: 4.11
Exactaly! lol, and if im gonna go through all the trouble of putting a dual on, its gonna be pretty legit. i dont think that ill really run into ground clearence issues, because the way my exaust is right now it hangs underneath everything, and i never have any problems with it
Old Sep 28, 2011 | 12:56 AM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
does anybody realize that the original post was almost 11 years ago to the day?
Old Sep 28, 2011 | 10:21 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Apparently not. Where's Pinhead?
gixxer92
May 18, 2017 11:20 AM
zman1969
Oct 1, 2015 11:09 AM
